Sony Cyber-shot  DSC-T10 Digital Camera Logo
A
Anonymous Posted on Feb 14, 2014
Error of E 62 20 PD 177 camera - Sony Cyber-shot DSC-T10 Digital Camera
R Olivier
Level 2:
Sergeant:
New Friend:
  • Sony Expert 74 Answers
  • Posted on Jan 27, 2019
R Olivier
Sony Expert
Level 2:
Sergeant:
New Friend:
Answers
74
Questions
0
Helped
63483
Points
570
Hello, The official list of error codes can be found at https://www.sony.com.au/electronics/support/articles/00008857 : E:62:20 indicates failure of the stabilizer, something that is unfortunately very frequent and recurring problem with all sorts of Sony camera's. I found more than 300 forums discussing the problem, please read http://sony-e-62-10.atspace.cc/. A temporary solution is also available on https://www.youtube.com/watch?v=S53D3EfDVk0. Hope this will help you.
Error code 177.what can I do.
Google your make, model and error code 177 to find out what the error is. You can then google for suggested solutions to the error.
I need pd 177 pc driver
hi,
DV cams are directly recognized by windows when lit up and pugged to PC by FW cable
you don't need drivers at all
My sony PD177 firewire por is Not working, it can't connecting to my PC
The problem with pd 177 its that it can burn the fire wire port and its not able to communicate with the pc you should check that the fire wire ports to see if they are working if they are then its the fire wire port that needs to be replaced.
Check the ebay you might be able to find one there.
hope that helps as my selfe had the same problem .
Sony Lens Cap for A100
The Lens cap model of the Camera depends on the model of Lens which you're using with the Camera. The model # of the Lens Cap for the Camera body and the lens differs. Few models and the details are given below:
55mm Front Lens Cap - G Series logo
Model Number: ALC-F55G
72mm Front Lens Cap - Carl Zeiss logo
Model Number: ALC-F72Z
77mm Front Lens Cap - Carl Zeiss logo
Model Number: ALC-F77Z
77mm Front Lens Cap - G Series logo
Model Number: ALC-F77G
α Rear Lens Cap
Model Number: ALC-R55
62mm Front Lens Cap - Carl Zeiss logo
Model Number: ALC-F62Z
49mm Front Lens Cap - Sony α logo
Model Number: ALC-F49A
62mm Front Lens Cap - Sony α logo
Model Number: ALC-F62A
62mm Front Lens Cap - G Series logo
Model Number: ALC-F62G
67mm Front Lens Cap - Sony α logo
Model Number: ALC-F67A
55mm Front Lens Cap - Sony α logo
Model Number: ALC-F55A
72mm Front Lens Cap - Sony α logo
Model Number: ALC-F72A
77mm Front Lens Cap - Sony α logo
Model Number: ALC-F77A
Please enter the SonyStyle webpage and check for the compatible ones for the Lens which you're using.
Thanks for using Fixya.
We wish you a happy holiday season..
I have a noise problem with sony pd 177
i want to bye camera but i could not decide which one is better pd177 or pd170
5helpful
Error:B0605 در پرÙ?Ù?تر HP2055 Ú?Ù?ستØ? Ú?راغ...
b0605 on hp laserjet p2055 connected to the network ...how do i sort this out ...khathu
1helpful
My Frigidaire electronic single wall oven FEB275ASB won't stop beeping. It displays a P4 error
F4 Shorted oven sensor (RTD) Check for shorted wiring between EOC and RTD. Check resistance of RTD using resistance table. If resistance test is correct and wiring is good replace EOC TEMPERATURE °F RESISTANCE ω 32 ± 1.9 1000 ± 4.0 75 ± 2.5 1091 ± 5.3 250 ± 4.4 1453 ± 8.9 350 ± 5.4 1654 ± 10.8 450 ± 6.9 1852 ± 13.5 550 ± 8.2 2047 ± 15.8 650 ± 13.6 2237 ± 18.5 900 ± 13.6 2697 ± 24.4
Driver
Does someone have the driver for a creative cardcam pd-1070
Top Sony Cameras Experts
ZJ Limited
ZJ Limited
Are you a Sony Camera Expert? Answer questions, earn points and help others
