Kenmore HE2 Plus Front Load Washer Logo
K
Kim Klein Posted on Dec 24, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Washer not draining but motor still hums
I get an F2 message during the drain and spin cycle. My washer will spin and I can hear the drain motor noise but it will not drain. I've taken everything apart except the hose from the drum and there's no clogs. I manually drain the water and start it again, but it just refills and gives me the F2 code again.
Eric Taylor
Level 3:
Master:
  • Master 590 Answers
  • Posted on Dec 26, 2017
Eric Taylor
Master
Level 3:
Master:
Answers
590
Questions
6
Helped
205994
Points
1556
I would get to the water outlet pipe and blow hard down it to try and clear any blockage if not take the pump housing apart to clear the blockage eric
5 Related Answers
antiochpc
Kevin Shafer
  • 1314 Answers
  • Posted on Jun 13, 2007
SOURCE: Loud noise when draining and spinning
It sounds like it has something to do with the pump which can be located in the direction of the noise. It could be something as simple as the belt wearing out or even just the pump came loose off of its mounts. Worst case scenario would be a new pump but it honestly sounds like something a little less intrusive. I know I had one that I had to hold down with a bungee cord because the mount had broken off of it.
Anonymous
  • Posted on Jun 26, 2008
SOURCE: Kenmore Elite H3t washer
What a blessing to find others with the same exact problem. Had a call in to Kenmore service center and was having to wait 8 days till a repair man could show up. Service call would have been at least $110 for the man to show up at the door. After discovering this website my wife and I are proud to announce that we found two (our 2 year olds) socks and one of my wife's nursing pads clogging up the filter along with some thread and a little gunk. Cleaned it out and in 10 minutes from start to finish we were done. Ran the machine twice and find it is running just like new. Like other postings here we found that a 45 minute wash took 90 minutes because the machine never could spin out on the first try. We thought it had problems balancing out the load of wash. Now it spins out quickly and without wasting time. I think of how much extra money it cost us to run the machine like this. Also, while we were sitting in our laundry room admiring the return of our washer I took a look at our complimentary Kenmore Elite HE3t dryer. Everyone who reads this far please do the following:
1. Unscrew the bottom panel of the dryer (unplug machine first)
2. Unscrew the black metal chute that goes from the lint catcher down to the blower (two sheet metal screws) pullout and clean.
3. Unscrew entire lint catcher from inside. (5 screws total) and clean.
4. Reinstall
5. One more step to really get all the lint includes pulling the entire machine out and removing the outside vent from the base of the machine. There is a 2 foot pipe to be cleaned out that extends from the other side of the blower.
I could not believe how much lint had bypassed the lint screen and had created a wall in front of the blower. I had previously checked the vent pipe leading to the outside wall and found no buildup whatsoever so I figured everything was okay. Was I ever wrong. I had found that the dryer (which is only 4 and 1/2 years old) was now taking 59 minutes to dry at normal temp instead of
the 41 minutes to dry when we first bought the machine. After I performed this service the dryer was back to drying the clothes in 41 minutes time or even less!!! In the future I will do this service, as described above, on a yearly basis. Once again we were wasting energy because we did not do this simple maintenance.
Anonymous
  • Posted on Jan 11, 2009
SOURCE: F2 error code on my Kenmore Elite HE3 washer
Had this problem on our Kenmore machine.
This is what done.
1. Unplug the washer
2. Take of the toe panel in the front by removing the three screws.
3. Get a bunch of towels (I mean a bunch!!!)
4. The pump is in the center, and it has a plastic grip handle that one can unscrew to remove the filter. As you unscrew it, LOTS of water will come out. Be ready with the towels. A cookie sheet helps to collect the water too.
5. Clean the filter assembly.
6. If one wishes to check the inlet of the pump, remove the back panel, about 12 screws. (Note, the following works for replace the pump as well)
7. Remove the large bellow from the bottom of the tub that goets to inlet of the pump by removing the clamp
9. Lift up on the plastic cover that covers the wires that power the pump. There may be a small plastic catch that is lifted up as to allow the connector to become free.
8. Remove the Torx screw that holds that is the center just under the filter screen.
9. Pull the pump forward.
10. Unclamp the pump outlet hose.
11. Remove pump
12. Unclamp the large bellow on the pumps inlet and inspect for debris.
13. Clean pump and fitler w/o getting water on the pump.
14. Install in reverse order. Remember, it is much easire to put the inlet bellow and outlet hose on the pump before you put into the washer
Anonymous
  • Posted on Apr 25, 2009
SOURCE: Washer will not Spin during SPIN CYCLES
Check the lid switch. Through out time the lid switch housing can come apart from years of heat and cold. When I checked mine, I found the glue deterriated and the housing came apart. What I did to fix it is I zipped tied the housing together and did a functional check and it worked.
Anonymous
  • 64 Answers
  • Posted on Sep 21, 2009
SOURCE: Kenmore 90 Series Heavy Duty Washer - Agitator doesnt spin
THIS IS A TYPICLE PROBLEM . BETWEEN THE MOTOR & THE TRANSMISSION THERE IS A COLLECTOR ASSEMBY (THREE PIECE
SET) REAL EASY TO GET TOO EASY TO FIX . ALSO COST EFFICENT
Washer agitates but won't spin or drain - makes a humming/buzzing sound during those cycles
check the pump,could have a sock or something stuck in it.usually i would say to check the lid switch,open and close the lid,if you don't hear a clicking sound the washer won't go into spin or drain but if you're hearing a humming sound that's the motor watch this video
http://www.youtube.com/user/RepairClinic?v=DwV71h86Gxw it will show you how to get to the pump.pop off the two clips that hold the pump on and remove the pump just pull it backwards off of the motor shaft,now get a piece of wire and strip the ends on it,2 to 3 inches long,unplug the washer before you start to work on it,get your jumper wire and stick it into the wire harness that connects to the lid switch, don't plug it into the ground plug it into the other two wires not the green wire,i'm pretty sure it's the two outside wires and the green ground is in the middle,plug the washer back in and pull the timer out in the spin cycle,if the motor runs and spins you know something is stuck in the pump or the pump is bad,but just to make sure it's not the lid switch and it is the pump put the pump back on and start the washer again if you hear the humming it's the pump or before you pull the pump jump out the lid switch and see if it spins and drains,if it doesn't then pull the pump so you don't have to stick the bad pump back on the washer,all the lid switch is for is so the washer will not run in the spin with the lid open and some washers won't even agitate if the lid is open by using the jumper wire we are bypassing the lid switch to check the washer while it's apart.hope this helps and if you can let us know how you make out so if someone else reads this with the same problem it will help them out too.
Glws1339cs1, started making noise like a belt was slipping during the spin cycle
Hello Bill Johnson - Is the washer draining or spinning? Could it possibly be a humming noise? If it is not doing either or and making a humming noise then it could possibly have a restriction in the drain line. Or either the belt is loose and will have to be put around the transmission and then spin it on to the motor or there is an issue with the lower/upper bearing. I would suggest contacting a professional to move forward accurately to properly diagnose/repair the washer.
I have a Maytag Quiet Series 200. In the beginning of the cycle, it makes a weird 'whirrrring' noise that goes away right after the first wash cycle. It's getting water. It's very noticable and I worry...
I have a quiet series 300 and it does that, too. I think it just balances the load before washing and is normal. I found this in the manual:
Normal Sounds
Your new washer may make sounds your old one didn
Rumbling noise during draining
i know with my fridgeadair it was the pump going out of mine , it would take me 3 spins to get the clothes wrung out enough to put in the dryer.
WASHER MAKES A HUMMING NOISE IN SPIN CYCLE BUT DOESN"T SPIN & CLOTHES ARE SOPPING WET.
what's the brand name and model number,all washers are different,most likely it's the motor humming or the pump is humming,could have something stuck in pump,if the water doesn't drain the washer won't spin,if you have a shop vac pull the drain hose out of stand pipe or sink,stick the shop vac hose onto the drain hose,get it down as low as you can and suck out the water and then see if it spins,if there's alot of water in the tub suck it out of the tub first then go to the drain hose,if it spins when water is out you know it's the pump but if you say water is still in tub i would have to say it is the pump,
Washer will drain druning the initial spin but not during the final spin
LD is a Long Drain code. You mentioned that there is an initial drain so this could be due to some lint or debis caught up in the drain line or drain tank. You will have to remove the black drain line and inspect to make sure all is clear. If you hear a humming noise while the cycle is in the drain cycle, your pump gears could be stripped. If this is the case - the pump will need to be replaced.
The C1 code is a motor current error. The source of the problem might be the motor, but will take more detailed electrical troubleshooting to find out.
Washer keeps stopping during any cycle
the humming noise could be from two sources and it is worth while doing a few simple checks first the drain pump is jammed with a foreign object. check nothing caught in the impellor second water not available - check taps turned on. also turn water off, undo fill hoses, put in a bucket and turn water back on try on drain or spin programs to check water drainage as well
Alexander
vince
