Question about HP Color LaserJet 5550hdn Printer
Hp color Laserjet 5550 59.C0 printer error message
    New Friend:
Hp_color_laserjet_5550_59_c0_printer
Posted on Feb 20, 2010
    New Friend:
I have hp 5550 color laserjet and it,s showing error 59.co. what can ido please.
roshan
Posted on Mar 14, 2010
  • 1,218 Answers
For those users who are having a problem with the printer motor, this C level problem is referred to as 'developing disengaging motor rotation error'. Most likely, this problem points to an issue with the function of the DC controller: either it has failed or it has affected the developing disengaging assembly. The solution is quite simple and the user may fix the error in a matter of few steps. The first step is to reconnect the J16 connectors that are used for the developing disengaging motor to the J1100 connectors that are used for the DC controller PCB (that is the printer circuit board of the DC controller). After connecting these two connectors to each other, the user must replace the developing disengaging drive assembly directly. The final step is to replace the DC controller PCB, after which the printer is to be recalibrated. get more information and help for Printer Error Code 59 c0
Posted on Sep 16, 2010
  • thihanlin Nov 01, 2010
    ok! Thank you. I gonna send my printer to service center. it's just out of my scope. :)
    New Friend:
I have hp 5550 color laserjet and it,s showing error 59.co. what can ido please. Tx.
segun
Posted on Feb 11, 2010
    New Friend:
Hp color lazerjet 5550 error 59.c0 .. please help me
Posted on Jan 13, 2010
    New Friend:
Emmax Greens
Action
  1. Press the green (Select) button to continue.
  2. If the error message returns, turn the printer off.
  3. Perform a cold reset.
    1. Turn the printer on.
    2. Watch the control panel.
    3. When the memory starts counting, press and hold the green (Select) button.
    4. (Select) button until the Ready, Data, and Attention lights flash once, and then stay on steady.
    5. Press (Down Arrow) button once. The control panel will display COLD RESET.
    6. (Select). The printer will perform a cold reset and then continue its power-on sequence.
Posted on Feb 06, 2014
3 Suggested Answers
6ya staff
SOURCE:
Londart
  • 3 Answers
SOURCE: 59 C0 error on hp color laserjet 5550
I had the same error, I had to take the left side cover off, (looking at the front of the machine) and found a small piece of paper that ended up right in the middle of a sensor flag! Of ALL the places to land. I pulled it out, it worked, end of problem! When you get the side cover off, the sensor flag is located in the middle/bottom of the printer. Hope this helps, happy fixin'.
Posted on Sep 08, 2008
Anonymous
  • 75 Answers
the printer is sensing that one of the motors are not turning.remove the cover from the left side .you will find the main drive motor,next to the motor you will find a sensor clean this sensor with some electronic board cleaner .be sure that the sensor it dry before turning the printer on.
Posted on May 10, 2010
Error59.c0
Per my service manual for this printer, the 59.C0 error states:
The product has experienced a developer motor error.
Recommended action:
1. Turn off the power by using the power switch, and then wait at least 30 seconds.
2. Turn on the power and wait for the product to initialize.
If the error persists, replace the developer motor.
If the error persists, replace the DC controller
Apr 08, 2014 | HP Laserjet CM2320nf All-In-One Color...
Its displaying an error code 59.c0 how can i solve this?
Error 59,c0: The developer-disengagement motor
experienced a rotational error.
1. Perform the Alienation Motor test in the
Component Tests menu in the
Troubleshooting menu. Verify that the
cartridges are being correctly alienated.
2. Check the following connectors: J25 at
the motor (M10), J261 and J251 on the
high voltage power supply-D PCA, and
connectors J138 and J106 on the DC
controller PCA.
3. Perform the Manual Sensor Test and
observe item G. The normal state is "0".
Locate the in-line connector J70 in the
cable that is connected to developinghome-
position sensor (SR11). To find
this connector, remove the left-side
cover and look in the area below the
support plate. Disconnect the in-line
connector. The state of item G should
change to "1".
4. If the motor is defective, replace motor
M10. If the sensor is defective, replace
the main-drive assembly
Apr 01, 2014 | HP CP3525N Color LaserJet Printer
HP CM1415fnw service manual
Error 59.C0 alguien qu epueda ayudarme ocn este error en mi hp cm 1415
Jul 24, 2012 | HP LaserJet Pro CM1415fnw Color...
Hp color laserjet code 59.fo error
All the book says is that one of the motors had a problem.
Power it off for at least 30 seconds. Power back on.
Make sure you are not using a surge protector.
Put the power cord directly into the wall outlet.
I just checked the manual for another printer and the 59.f0
could be the ITB. Make sure that it is seated correctly. If you have
a spare install it and see if problem goes away.
Apr 04, 2011 | HP Laserjet Cp2025n Printer
Dec 17, 2009 | HP LaserJet 5550 Printer
HP Color LaserJet 5550hdn Printer Logo
15,592 people viewed this question
Clive
Clive
Ekse
Thomas F. Schneider
