Question about Vittorio St. Angelo Mens 2 Piece Short Sleeve Walking Suit -
2piece line set - Vittorio St. Angelo Mens 2 Piece Short Sleeve Walking Suit -
How do I set dial tone on line 3?
If you mean for line 3 to be selected when you pick up the handset, you need to program that as the "prime line" for that set.
Sep 30, 2015 | NorStar M7310 Corded Phone
How to get incoming calls to two handsets
The system should be configured so that the desired lines, whether CO or extensions, are set to "Appear and Ring" on each set.
Config... Terminals&sets... Show Set... (enter #)... Find...Line Access... Line Assignments... Show Line (enter #)... set to "Appear and Ring" on each set that needs to ring.
You can also have a line "Ring Only" without an appearance (dedicated button), in which case it will show as an intercom call.
Sep 25, 2014 | NorStar T7316E Telephone
Is a 2004 ford f-150 2wd carrier bearing.. ( mid-mount bearing ) on driveshaft replaceable, or do i have to replace entire driveshaft?
it is replaceable
normally it comes complete in the rubber mount
you will have to undo the drive shaft flange at the bearing
remove the drive shaft and take it to an accredited drive shaft repair shop or take the vehicle to an accredited drive line specialist shop
the repair will require that you place the flange back on the shaft after the bearing replacement in exactly the right position or you will get harmonic vibration after the job so talk with the experts first if you want to diy
May 09, 2017 | Gateway Cars & Trucks
How do you replace the rear engine seal on a 84 c1500 350
You will have determine if its a 1piece seal or 2. If its a 1piece rear main you will have to remove transmisson to install. If its a 2piece you will have to remove the oil pan to replace.Hope this helps
D.
Sep 28, 2010 | 1984 Chevrolet C1500
How do I set phone to ring at my extention?
Partner, all releases.
Examples
Receptionist Call Routing. If you want calls to be answered by the receptionist first, set the lines at the receptionist’s extension to Immediate Ring and the lines at the users’ extensions to No Ring. (This is the factory setting)
Receptionist Backup. If you want all calls on a line to ring directly at users’ extensions -with the receptionist providing backup -set the line at the users’ extensions to Immediate Ring. Then set the line (or lines) at the receptionist’s extension to Delayed Ring. An incoming call that is not answered by a user within 20 seconds will also ring at the receptionist’s extension.
Programming
To change the way outside lines or pools ring at an extension:
  1. Press [ Feature ] [ 0 ] [ 0 ] [ System Program ] [ System Program ] [ Central Tel Program ].
  2. Enter the number of the extension to be programmed for Line Ringing. The green lights next to the line or pool buttons on the phone show the current Line Ringing settings for all lines assigned to the extension. (If a line is not assigned to a button, the green light next to the button is off.) The following ringing options can be shown by the green light next to the line button.
    • Immediate Ring - on steady
    • Delayed Ring - flashes slowly
    • No Ring - flutters quickly
  3. To change Line Ringing for any line, press the line or pool button until the button light shows the correct setting (the setting for the currently selected line or pool also appears on the display).
  4. Continue programming or exit programming mode.
Dec 01, 2009 | AT&T Lucent MLS-12D Phone
Replace old vinyl/plastic type stand up shower - I want to convert over using tile. What do i use as a bottom pan i can tyle over?
You could make a base that would be framed up 2x4's and covered with a waterproofing membrane. lay concrete floor, sloped to drain (2piece) and tile. Or use a fibergass base that fits to studs. And then tile walls.
Sep 21, 2009 | Home
Setting on knob of diplomat oven
Im pretty sure that settings mean on the 1 line top element only comes on and 2 lines both elements come on hope this helps
Sep 06, 2009 | Ovens
M7310 - 3 phone set system - line 3 on one set does no ring tone
Feature * 6 is for the ring tone of the set, it doesn't change the cadence (ring tone) on a line...
The only way to change the ring tone on a line... it would require everyone that has that number to change.
You need to go into the programming
-> look for LINE and enter
-> put in 003 for line 3 and enter
-> under TRUNK/LINE DATA find DISTINCT RING and change
-> REL to end programming...
Now that line 3 will ring differently. But it will ring differently on everyone's sets that has line 3 on their phone
Mar 04, 2009 | NorStar Meridian M7310 Phone
Stop ringing at certian phones when outside calls come in.
http://dstech1.com/programming-line-ringing/
Examples
Receptionist Call Routing. If you want calls to be answered by the receptionist first, set the lines at the receptionist's extension to Immediate Ring and the lines at the users' extensions to No Ring. (This is the factory setting)
Receptionist Backup. If you want all calls on a line to ring directly at users' extensions -with the receptionist providing backup -set the line at the users' extensions to Immediate Ring. Then set the line (or lines) at the receptionist's extension to Delayed Ring. An incoming call that is not answered by a user within 20 seconds will also ring at the receptionist's extension.
Programming
Jan 09, 2009 | Lucent PARTNER18 Corded Phone
Help
Sounds like it needs a new fuel pump. Get a Fuel Pressure Gauge and check it make sure it up to the Specs,What I think is about 35 to 40 psi without looking in my book. Also you would want to make sure the fuel filter was changed, Your getting spark and fuel, But You stated your able to start it with starting fluid so I would say it must be a fuel pump problem.. I hope that help you out. If not get back to me and we can try some more trouble shooting. Take Care, Bear
Jun 11, 2008 | 1993 Chevrolet S-10 Blazer
Vittorio St. Angelo Mens 2 Piece Short Sleeve Walking Suit - Logo
385 people viewed this question
Top Vittorio St. Angelo Clothing Experts
ray gallant
Andrew Taylor
Andrew Taylor
Jim Pattison
Are you a Vittorio St. Angelo Clothing Expert? Answer questions, earn points and help others
