Question about Winchester 10x25 Hunter's Grip Binoculars
My Chinon 10x25R binoculars have the same problem.
They are excellent glasses, but the horrible sticky "grips" make them unpleasant to use.
Can they be cleaned?
HELP!!!!!!!!!!!
    New Friend:
Simple use soft lint free cloth like old drying up cloth, you need about half a cup of methalayted spirits,can get this from any hardware store.
poke finger into cloth dip into meths proceed to rub sticky coating off binoculars. you will need to keep changing to a new peace of the cloth as soon as it gets coated with the sticky black stuff off binoculars.
keep dipping into meths eventually after say 6 rubs in a particular area you will see and feel a nice hard black plastic, continue all over effected area then finish off with any window cleaner polish until cloth remains clean.STICKY COATING IS NOW GONE IT WAS INFACT A COATING PUT ON THE BINOCULARS TO MAKE THEM NONE SLIP. job done. regards GER8
Posted on Feb 07, 2013
  • Deb Geiger Jul 06, 2013
    Thank you so much!!! I raided the garage and found the denatured alcohol, took an old T-shirt of my hubby's (a good sacrifice, since I'd moments before been online looking at new, non-sticky binocs) and went to town on my Bushnells! All the sticky is gone, and I shined them with Windex for a brand new look! I also took my denatured alcohol rag and wiped down my straps - perfect! I'm very grateful, as I wasn't looking forward to making a decision on new binoculars - too confusing and I like what I have. Great advice, ger8ger8!
I to have a pair of Chinon 7-15x25 zoom binoculars again with a sticky outer case.
Any ideas how to clean?
Posted on Sep 23, 2010
    New Friend:
I had the same sticky mess on Bushnell National Audubon Society binoculars. Did not want to be aggressive with any solvents, so I used Spray Nine to remove the black, sticky coating. The shine on the plastic surfaces are clean and unharmed.
Posted on Mar 24, 2014
I had this with my Chinon. Warning...This may remove printing such as the makers' name from the binoculars. First remove the strap (mine went into the washing machine and came out clean and non sticky). Find a plastic receptacle that your binoculars will fit into and pour in "Tesco Value" "All Purpose Cleaner" to about one inch depth (check on-line for this if you don't have Tesco). Let the binoculars soak in this for an hour or so, turn the over and soak again, make sure that all of the case gets a soak. Being careful not to scratch the lens scrub the old sticky coating off with a stiff sponge or an old used pan scourer (I used both. Make sure that the scourer is old, used and not too abrasive). Keep dipping the scourer/sponge and binoculars in the cleaner as you do this. When you are happy that you have removed the sticky coating, wash your binoculars thoroughly under a warm water tap (faucet) and leave them on a radiator to dry out (mine took about a week).
Posted on Jan 22, 2012
6ya staff
SOURCE:
Canon eos sticky handgrip
Old cameras get this sticky handgrip problem.
Clean it with alcohol.
Jul 14, 2012 | Canon Digital Rebel / EOS-300D Digital...
I have Bushnell Powerview 13-2521 which are about 12 years old. The coating on the exterior has tiurned
I cleaned my Tasco binoculars with Goof-Off and it seemed to work well. It was in horrible shape, with really sticky black goo.. now it feels smooth and clean again. Don't know how long it will last though.
Apr 16, 2012 | Optics
The grips on my binoculars has got very sticky, any suggestions to clean off please.
WD-40 to clean the stickiness and then rubbing alcohol to clean off the WD-40.
Mar 02, 2011 | Cameras
How to install bar ends on a bmx bike
If your grips have closed ends, cut a section off so you have plenty of grip left, but a hole where the bar ends can go through. Follow below procedure with the bar ends.
Bar ends are either have a screw or allen key head. Tap them into the ends of the bars with a rubber mallet. Tighten up the screw/bolt as this will make them expand keeping them inside the bars.
If you need to remove the grips:
Get some hairspray and lift the edge of the handlebar grips up, spray down until the grip is slippy and comes off. (Only use hairspray though, as once it is slippy, it will be very sticky in a minute so it will help when you replace it. Repeat for the other grip. Clean up the bars where the grips were. Refit the grips with more hairspray inside the grip and a little on the bars. Slide them on and leave for a good 6 hours so they stick.
Hope this helps mate, please vote for me :)
Jul 02, 2010 | FEDERAL BMX Bike Grip Red Nylon Bar Ends
Rubber grips get sticky after a time instorage. How
Try using some rubbing alcohol on it. Should be able to clean it up.
Apr 12, 2010 | Canon Rebel XT / EOS 350D Digital Camera
Copies run through feeder distorted
Document feeder Paper feed rollers should be cleaned with alcohol, blow out the document feed area with compressed air (computer duster), check feeder for bits of paper, post it notes, and signature flags. Clean glass, check for sticky areas on the glass.
Hope this is of some help.
Ed
May 12, 2009 | Toshiba E-Studio 3511 Color Copier
Very sticky handles on Maclaren Techno XT buggy. Not grandchildren as they are only small. Any solutions please?
ok as they are sticky it means you have eft them out side or in the rain
simply just put cling film over the top of the handles it realy works !! :)
Nov 08, 2008 | Maclaren Techno XT Wisteria Umbrella...
Winchester 10x25 Hunter's Grip Binoculars Logo
4,108 people viewed this question
Top Winchester Optics Experts
james laughton
james laughton
Colin Stickland
Colin Stickland
Fahr Quad
Are you a Winchester Optic Expert? Answer questions, earn points and help others
