I bought this refrigerator new two years ago. Last week the freezer wasn't working so I adjusted the temperature and it began to get cold again. The new problem is that some motor comes on exactly every 4 minutes and stays on for about 20 seconds.
Any ideas on what my problem is?
SOURCE: Kenmore Elite Trio 596 73503200
Did you ever get the problem fixed with the compressor noise
SOURCE: elite trio
Hello bigmikeegator
Welcome!
You said, you have the Kenmore Elite Trio Bottom Freezer. You moved your refrigerator
to a new home and removed the bottom freezer door, but can not seem to
figure out exactly how to put it back on correctly.
It's too much for me to tell you myself.
This is easier!
Page 9 shows you how to remove and reinstall doors.
http://www.managemyhome.com/mmh/lis_pdf/OWNM/L0523115.pdf
Thank you,
Huuum,
Please remember to leave a rating!
SOURCE: Kenmore Elite Trio Fridge Not Cooling
check the over-load/contactor on the side of the compressor,remove it and shake it if it rattles,replace it
Testimonial: "That's what my fridge is doing? Thanks for the help."
SOURCE: The temperature settings for the refrigerator and
I have the same problem with this refrigerator. It looks like Sears Parts Direct sells all the parts for this unit except for the printed circuit board and temperature control switches. I called my local repairman and set up an appointment. He called back to cancel his appointment because he was also unable to get the electronics. Were you able to fix your unit? What did you replace?
The Fridge works fine. The freezer stops working and makes a noise. It starts thawing. Later it is back to normal. It has now done this twice on its own.
Lack of cooling. I had the same problem two years ago and it was the defroster switch was stuck and had to be replaced.
Can anyone tell me how to get at the defrost switch?
not getting cold
