SOURCE: Ilo remote control code
Yes the Emerson code 198 worked for my jumbo universal remote made my Innovage. I also have the ILO 32' TV and could not find the code but this one worked!!! Hope it helps
SOURCE: code numbers to set up iLo tv
Checked on line for any code there was that someone used for iLo t.v.'s, found two codes on your site that someone had used & used those & one of them worked. Thanks again!
SOURCE: ilo tv/universal remote codes
Here are some to try, mine was 0189, but there are many to try. 0051 0189 0053 0198 1070 1024 1023. I think some listed codes for Emerson work as well.
SOURCE: ilo TV, universal remote
Ilo is made by Orion and/or Sansui.
My Ilo dtv2794B was programmed on Direct TV remote as follows:
In Direct TV mode press 'menu' .
Go to parental ,faves setup
Go to system set up
Go to remote
Go to TV
Select brand (Orion)
Follow directions from this point.
Good Luck>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>
SOURCE: TV remote codes
press menu and go to settings. select remote, code search and follow the on screen instructions it may take a few minutes to locate the correct code but it is in there.
the installer told us that the remote could not be programed to our ILO tv, he was wrong I made it happen without any trouble.
