Question about Canon PowerShot SD800 IS / IXUS 850 IS Digital Camera
Video sound is all static
When playing back video, the sound is all static.
2 Suggested Answers
Anonymous
  • 9 Answers
SOURCE: No sound when recording video
Did you set up the camera to capture sound? This Camera has a Functions menu which is deep as the ocean, and standard movie capture does not also pick up sound. Additionally, if playing the movie back over an external device, use the A/V cable not USB, and get a High Capacity SD/MMC memory card if you want more than a few moments of video with sound. I would finally recommend an audio input device, as even when in Movie sound capture mode, the volume is never very loud.
Read the advanced manual completely.
Posted on Dec 25, 2008
SOURCE: My Canon PowerShot SD300 was
When you play the video back and get no sound are you doing this on your camera or on the computer? I have the same camera, and noticed that when I playback something I've recorded I don't have sound either, mind you I don't have static either. But once I've uploaded the video onto my pc the sound is there.
Posted on Jan 15, 2012
Static lines through screen.how wont turn back
a circuit in the game system broke down, either the power supply or the video circuit, most likely a capacitor shorts out.
Oct 07, 2015 | Video Game Consoles & Games
I recorded videos at a concert with the new nikon coolpix L810 and the sound on the video is horrible.What is causing the noise in my video? sounds like wind is blowing or a crackling noise
The problem is the microphone on the camera. The mic on the camera is for recording sound in more normal environments. The sound level on a typical concert is much higher than normal, and the mic on the camera just doesn't have what it takes to record sound at those levels.
One possible solution is to record the sound with a dedicated audio recording device, and combine the video and audio in your video editing software.
Jul 02, 2012 | Nikon Coolpix L810 16.1-Megapixel Digital...
My Canon PowerShot SD300 was recording sound perfectly a few days ago. Now whenever I record a video and play it back there is no sound except for static. I have resetted the settings to factory defaults...
Jul 29, 2011 | Canon PowerShot SD300 / IXUS 40 Digital...
Static noise; no sound
I belief that static sound leads to Graphics Video card failure which is integrated on the motherbord, i suggest you take the notebook to the nearest retailer and repair .
Apr 01, 2009 | Dell Inspiron 1300 Notebook
There's no video when playing, only hear audio on the menu screen
sounds you are not wired right! have manual around? Type in google engine brief phrase about problem
Mar 12, 2009 | Sanyo Televison & Video
Pioneer VSX-D85OS very loud static through speakers.
Its over heating no cheap fix. But wait if u buy an eternal fan n place it on top or behind it will do the trick. Try blowing on top when static happens n sound comes back on.
Nov 07, 2008 | Pioneer VSX-D509S Receiver
Logitech Communicate STX videos plays back static!
Normal 0 Two things can cause static.
First, If you have your speakers turned up to high it will give you feedback causing distortion and static. I recommend using a headset when videoing.
Second reason is, if you are using a laptop and have added an external microphone between the two it will cause distortion and static.
Not knowing the configuration of your computer makes it harder to analyze the problem.
So hope this is of some help. Bud
May 22, 2008 | Logitech QuickCam Communicate STX Personal...
Recorded Video Plays back static
May 15, 2008 | Logitech QuickCam Communicate STX Personal...
Audio static
Hi: An alignment of the video if and or the audio circuits may be necessary in a repair shop.
How old is this set?
Al
Mar 17, 2008 | Televison & Video
Canon PowerShot  SD800 IS / IXUS 850 IS Digital Camera Logo
Top Canon Cameras Experts
old marine
old marine
Ekse
Poul Brinchs Larsen
Are you a Canon Camera Expert? Answer questions, earn points and help others
