SOURCE: LG front load washer is gettign an error code of
FE means overflow condition. That means sand or trash has gotten into the tube going from tub to water level switch. So find that hose and blow it out. Remove the standing water and retry.
SOURCE: I have an error code it looks like an upside down F and E
on the back of the stator...the inside of the motor the part that has the whindings.plastic overload replace it..if you need help i will talk you through..also look for water or a drip ...onthejob
SOURCE: My LG WM-2277HW front load washer has an error
This is a water overfill condition and many things can be causing the issue.
Leaking water valve.
Plugged water lvl. switch hose.
Problem with the main computer.
A service call may be needed.
SOURCE: My washer is blinking upside down F and E. Manual
It is actually a TE and should be the thermistor Part#
1268202
In case anyone else has this question I was able to fix it.
The Manual states the main issue with this problem usually is the thermostat because the washer is vibrating to much. The manual walked me through taking the front off, come to find out I could just flip it on it's side and access the thermostat from the bottom with no reason to take the front off. Found a broken blue wire running to the thermostat and was able to splice it back together and it works fine.
