Samsung S8300 Ultra Touch platinium-red Cell Phone Logo
Posted on Jun 09, 2009
Cannot set time and date,
I tried manually,restarted,but has the date as 01/01/2005
Anonymous
Level 1:
Problem Solver:
  • Contributor 6 Answers
  • Posted on Jun 11, 2009
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
6
Questions
0
Helped
1156
Points
18
My Tocco Ultra works by just going into Menu, Settings, Time and Date then scroll up until you get the Time window. Tap on the time window and the hour is highlighted for you to type in the hour, then when you've done that the minutes get highlighted so you can type them in. then you need to tap on Save at the bottom. Hope it works for you
Why dose recording in dvr goes on default date when light goes
Well, I'm trying to decipher this. Why does the recording in DVR revert to the default (date/time???) when the light goes off and comes back on.
I'm guessing you are trying to say time, not date, maybe day?
The DVR is trying to remember when a show comes on and record it, based on your settings. Usually shows come on at a specific time. DVRs usually update their scheduled recordings based on updated programming guide information. If you are constantly unplugging or causing your receiver to otherwise restart, most receivers will download an updated guide upon getting power back or restarting (DVRs themselves not having any idea how long they've been without power, download a new guide just in case after you unplugged them you moved to Arizona). During this time, the recording you set is showing the original time you set it up, because until the guide is downloaded, it has no idea that its wrong.
My best advice, even if I'm wrong about our language barrier here, stop unplugging your receiver. Leave it plugged in and powered at all times.
All times.
For ever.
I keep getting certificate error when i try email
its due to incorrect date and time set correct date and time it will be solved and if u r loosing ur seted date and time again and again after restarting ur computer den replace ur cmos battry
When i want open a website then we get a problem below the addressbar "Certificate error" mostly Google\orkut\ & also mozila firefox. please give me solution for this problem..
Hey!
Try checking the Time and Date settings of the computer. Time and Date settings can greatly affect programs that access the internet. Try correcting the Time and Date settings. After correcting it, try browsing some websites where you get certificate errors.
After doing that, restart your computer. If the Time and Date is wrong again, it means that there is a problem with the CMOS battery(complimentary metal oxide semiconductor). This battery saves the basic settings of your computer which includes Time and Date settings, boot up device settings, etc. If that's out of charge, best option is to replace it. Here's an sample image of it. It's just like a watch battery but a bit bigger.
Hope this helps! :D
2answers
I set my computer date and time but i restart the
you need to replace the battery inside the laptop
2answers
How to set the time on Magellan
TO SET TIME ON EXPLORIST 100 CLICK ON MENU CLICK ON PREFERENCES CLICK ON RESTART GPS SELECT YOUR COUNTRY CLICK ON YOUR STATE THEN SET TIME.
2answers
Faulty time settings p5rd1 vm
Hello!
That's the 2nd time i hear that kind of problem. Your mboard battery is new, and you did not press "f1" at first start.
so i guess , the cmos time is not change, try go to the bios setup and load "bios setup default." after that change the time setting on the bios. please find time setting and set it with a current ime in your area. after setting press 'F10" to save and exit the setting, the system will restart.
may this help!
best regards, melnavz
Adjust the date on the i70
Hey Mat,
You can find your product manual here:
http://www.samsungcamera.com/popup/download.asp?prol_uid=4148&prj_uid=733
You'll find once you download the manual's pdf, it'll be on page 20 of the pdf manual. The sample is below, but it's much clearer on the pdf manual. Best of Luck!
When Using the Camera for the First Time : Setting up the Date / Time and Language
When the camera is turned on for the first time, a menu will be displayed
in the LCD monitor to set date, time and language. This menu will not be
displayed again after setting up the date, time and language. Set up the
date, time and language before using this camera.
■ Setting up the language
1. Press the [Language] menu button.
2. Select a desired language by pressing the
vertical smart button.
■ Setting up the date, time and date type
1. Press the [Date & Time] menu button.
2. Select a desired date type by pressing the
3. To change the date, select the [2008/01/01]
menu and press the vertical smart button.
4. To select Year / Month / Day and Hour :
Minute, press the horizontal smart button.
To change the numbers, press the vertical
smart button.London
● You can select any one of 22 languages. These are listed below :
- English, Korean, French, German, Spanish, Italian, S.Chinese,
T.Chinese, Japanese, Russian, Portuguese, Dutch, Danish,
Swedish, Finnish, Thai, Bahasa (Malay / Indonesian), Arabic,
Polish, Hungarian, Czech and Turkish.
● Even if the camera is restarted, the language setting will be
maintained.
G3 time issue
6d7cb5a.png IF YOURE running tiger, go to the apple top left screen, drop down menu, choose SYSTEM PREFS....it should look like..... 27828b5.png 3rd item on 4th row......you can select it manually or let it set by netowrk if you have access to the internet at the time. Now if your date and time keep setting back when you restart your computer, you may need to zap the PRAM (****-ram). Also if your battery is not reliable or not keeping a proper charge, that will affect your machines time and date.....try checking your battery's cycle....... www.coconutbattery.com
Top Samsung Cell Phones Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Mike Cairns
Mike Cairns
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
