Frigidaire GLTR1670A Front Load Washer Logo
A
Anonymous Posted on Nov 19, 2017
Front load frigidaire one year old and cycle won't start from one day to the next. The panel lights are indicating things are correct but the door lock light does not go on when I press start and the start light blinks instead of staying on. Water does not come in. All obvious things checked inc voltage.
Kenneth Simmons
Level 3:
  • Frigidaire Master 1,239 Answers
  • Posted on Nov 19, 2017
Kenneth Simmons
Frigidaire Master
Level 3:
Answers
1239
Questions
Helped
753199
Points
4061
I have had to change the door switch on every washer and drier I have ever had. Just a thought: If the door switch is bad the drier and washer will not start working. The one I changed on my drier about a month ago, when I opened the door and played with the switch while pushing the start button it finally came on. I changed the switch and no more problems. If the door is open the dryer and washer are not supposed to operate. I have changed some which you could not move around on those I would pull the wires off the door switch. Depending on if the switch is normally open or closed I would connect the two wire and try to start or leave them separate and try to start..
  • Kenneth Simmons Nov 19, 2017
    I never had a front load washer so I assume it has some kind of door switch. Hope this helps if not Sorry
5 Related Answers
Anonymous
  • 94 Answers
  • Posted on Oct 28, 2008
SOURCE: Fridgidaire front load not starting
hi fourintow
sound to me that its the water inlet valves at the rear of the machine,they're the bits where your blue and red water hoses joint on to they are quite cheap and easy to install
Anonymous
  • Posted on Dec 26, 2008
SOURCE: My frigidaire will not go through any cycles>
It may have defaulted to 8 hour delay, ours did after a storm and the power went off, see if the 8 hour delay button is lit, if so press to return to instant wash.... hope this helps
Anonymous
  • 15935 Answers
  • Posted on Aug 13, 2010
SOURCE: Frididaire (LFT2140FS) Front Loading washer - Did
Thanks for your question!
I'm sorry that you haven't received an answer yet.
The response rate on FixYa FREE questions is usually over 80%, but sometimes questions go un-answered when:
1. the question is unclear, incomplete, or poorly worded...
2. the question is mis-categorized - so the correct experts aren't viewing it...
3. the question requires an answer for something that cannot be explained online adequately...
4. specific training, tools, or equipment are required to avoid injury or death...
5. the Experts that are online simply don't have the resources to answer your question fully...
Please feel free to re-work your question if you feel one of these may be the reason.
Of course you are not required - but converting your question to a PAID one usually increases the reply rate as well.
Normal rates for FixYa are...
$ 9.99 answer for one question.
$12.99 Live Real-Time online chat or premium e-mail support.
$29.99 Live Real Time phone support
Sometimes FixYa will run specials for unlimited questions via monthly subscription or reduced rates for limited periods.
If you don't want to pay - feel free to re-submit your question so it returns back to the top of the work queue if you still need help.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Anonymous
  • 4323 Answers
  • Posted on Sep 25, 2011
SOURCE: I have a Frigidaire front loading washer LTF
Hi
Press and HOLD the Start/Pause and Cancel buttons simultaneously. As long as the buttons are held, the failure code will appear in the display as an E followed by two numbers, a number and a letter or two letters, please post back with the error code for further assistance.
Daniel
chrispolkele
Electrolux
  • 4342 Answers
  • Posted on Sep 04, 2012
Our people make the difference
    Verified Fixya Pro
    SOURCE: Frigidaire front load washer will start and after about 2 seconds will stop. Lights will go from normal working to no spin
    From what you have described I would have a professional diagnose the unit's timer and main control board for possible replacement of those parts.
    Frigidaire front load washer LTF2140FS2 stops after every cycle and the start light blinks
    Good Afternoon Nicole, thank you for allowing me to assist you!
    Typically, the Start light flashing indicates that the cycle has paused or the door is not securely latched. If the hose is not clogged and the door is closing properly, then more than likely your washer is experiencing a communication problem with the control board or wiring issue. At this point, I would strongly recommend contacting a professional to make the necessary repairs.
    Best of luck!
    FRIGIDAIRE FRONT LOAD WASHER WON'T START. DOOR LOCK WILL NOT LOCK. DOOR LOCK LIGHT IS OFF. PULL START HANDLE OUT/ NOTHING. HEAR CLICKING WHEN TURNING SELECTOR SWITCH/BUT WILL NOT LOCK DOOR OR TURN LIGHT ON...
    Good Morning REDS, thank you for your inquiry!
    I understand that your door indicates it is open and your washer will not operate. Try resetting the unit by either unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes and turn on the washer. Select a normal cycle, confirmed the latched is securely latched and verify if the washer will start. If the washer will not operate then it possibly have a faulty door lock assembly or a communication problem with the control board. At this point, it would be advisable to contact an experienced appliance repair tech to assist further.
    4helpful
    My Affinity Front load washer, Model #ATF7000ES1
    I am having this same exact issue, have you figured out what the was?
    I have a frigidair front load washer 4 years old it pumps water out but will not spin at anytime can u help
    is the door locked and the locked light on???
    these things will not spin if the door does not lock and register with the control unit that it is so.. latch may need replacement.
    does it move at all, in any cycle??
    if not the belt may have came off, theres usually a reason why tho, investigate and correct.
    worst case scenario you will have to locate the technicians data sheet inside the lower part of the unit (i hope) and check the diagnostics button dance out and follow through the diagnostic for your units problem..
    you may find the motor or motor controller to have defected.
    hope this helps,
    best of luck,
    ttfn
    1helpful
    Won´t spin at all in any cycle
    Goto http://www.frigidaire.com/manuals and download the model wiring diagram. It will explain how to view and interpret additional error codes. I have the exact same issue with my machine (will not spin). The error code #E47 indicates that the machine thinks the door is open and will not engage spin. Fixes: new door switch ($85) or new control board ($285).
    5helpful
    My Frigidaire affinity washer doesn't start: the "door locked" button doesn't come on though the door is closed properly
    If the washer fills with water, but will not start the wash cycle or spin, it is 1 of to things. the most common for frigidaire front load affinitys is the door lock assembly. I have had to replace numerous of these. if the door lock indicator is not on when it tries to wash, you need to replace the door lock assembly. if the door lock indicator is on, but wont wash, it is likly that you have a bad motor control board.
    Wont start any cycle
    Go to your door latch, there is your first stop.Your power supply waits here at the latch to give the computer a correct start.If its not the latch....I need to know. Post a update on this one. Thanx!
    Top Frigidaire Washing Machines Experts
    ZJ Limited
    ZJ Limited
    Mike Cairns
    Mike Cairns
    Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
