Strats and runs well but after shut down will not start again for approx 3hrs
is there a heat sensor
when it will not start in acts as if its not getting fuel or spark?
The manual contains a schematic which does not show a heat sensor. You need to narrow it down to a fuel or spark problem. The easiest to check is spark. If you do not have spark, it could be the plug, wire, oil level sensor, magneto, coil or TCI module. If you have spark, then it is likely a fuel problem. Open drain and see if fuel is getting to the bowl. If not, check tank, valve and lines. If yes, it must be the carburator. Good luck.
