Question about Samsung Galaxy Tab 2 7.0 16 GB 3G Wifi Unlocked Black
Battery or OS problems
Can someone help my tab? Probably OS problems. Hello people, can you help me? My Galaxy Tab 2 P3100 has problems with its battery reading part of the OS. When I use it when its still 90%, a few minutes with video makes it go to 1%. When I charge it from being completely drained out, it takes just a few minutes before it says full charge. When I just leave it from using it, it sometimes increases its battery percentage, and it is not connected to the charger or anything. I know that the battery is not the problem because it takes long before it is completely drained(It takes 4 hours of 1% often). Thanks for your help.
  • Vincent Campos
    Vincent Campos Mar 21, 2014
    but it is already 1 year old, and it started just after being auto-updated. So there is really nothing I can do except asking pros to fix it? thanks for answering to this problem.
  •  Mike M
    Mike M Mar 27, 2014
    So it's like a faulty gas gauge. Well, you can't over charge a L-ion battery! Leave it on charge when not in use.
  • Samsung Master
  • 3,324 Answers
This is not an OS issue. Either your battery is defective or the sensor reporting the battery charge state is defective. If you have warranty time left get it fixed or get a new unit.
Posted on Mar 07, 2014
  • 1 more comment
  • Vincent Campos
  •  Mike M
    Mike M Mar 21, 2014
    Try running the update again. Aside from the indicator is there any sign that the battery is not working as it should?
  • Vincent Campos
    Vincent Campos Mar 27, 2014
    Actually, it is already in the latest version, so I can't update it. and the thing I can say about it not working as it should is the info at start.
4 Suggested Answers
6ya staff
SOURCE:
jonags3
Jonathan Agawin
  • 83 Answers
SOURCE: My Galaxy Tab 2 Wi-Fi cannot find my wireless network
Hi! Go to settings then activate your connection using the wifi. select wifi only then it will turn on. go to main menu and check if wifi is ready, If it will not show after doing it. try to shutdown your phone then turn on again after 5 seconds.
jonags3@mail.com
Posted on May 07, 2012
jadiazq
Jose Diaz
  • 2878 Answers
SOURCE: just installed an external memory on my Samsung Galaxy tab 2, 7 how to start using it
First make sure it is ready and formatted. Then treat like any other drive.
Posted on Nov 22, 2012
My tablet has safe mode in left corner,hOW DO YOU SHUT IT OFF?
Get an Android Tablet out of safe mode - Support Home Page
acer--uk.custhelp.com/app/.../get-an-android-tablet-out-of-safe-mode
How do I get my Android tablet out of safe mode? Use the ... Restart your device by holding the power button, then tap Power off. ... Did this answer help you?
Samsung Galaxy Tab 3: Turn Safe Mode On or Off
www.technipages.com/samsung-galaxy-tab-3-turn-safe-mode-on-or-off
Mar 15, 2014 - Use the Safe Mode feature on the Samsung Galaxy Tab 3 to start the Android OS with the system default software. ... When the Galaxy Tab 3 logo appears on the screen, press and hold the "Volume Up" button. ... Once the device has completely powered off, you can press the "Power ...
Galaxy Tab 4: Enable or Disable Safe Mode - Technipages
www.technipages.com/galaxy-tab-4-safe-mode
Mar 4, 2015 - A tutorial about how to turn Safe Mode off or on for the Samsung GalaxyTab 4 tablet.
Power the Device Up in Safe Mode - Samsung Galaxy Tab 2 ...
Jan 20, 2016 | Tablets & eReaders
How can I reset my Galaxy tab 2 7 to its original settings?
Samsung Galaxy Tab 2 7.0 - How to perform a hard reset with the ...
https://www.androidpit.com/.../samsung-galaxy-tab-2-7-0-how-to-perfor...
Jun 18, 2014 - Samsung Galaxy Tab 2 7.0 - How to perform a hard reset with the ... From the Backup & restore section, ensure the appropriate account is ... In Menu mode, select Settings ? Privacy ? Factory data reset ? Reset Tablet? ... Samsung Galaxy Tab 2 10.1 - How to perform a hard ...
Jun 18, 2014
How to Hard Reset the Galaxy Tab 3 - Android Forum ...
May 7, 2014
More results from www.androidpit.com
Galaxy Note 5: How to Perform Soft & Hard Reset
www.technipages.com/galaxy-note-5-how-to-reset
Aug 23, 2015 - If you want to sell or give away your Samsung Galaxy Note 5, or if you're ... The hard reset will wipe all files off of the internal memory, as well as ... your phone and just perform a factory reset as a way to make it their own. ... November 7, 2015 at 3:44 pm ... I have problem with my Samsung Galaxy tab 2 ...
How to Hard Reset/Factory Reset Samsung Galaxy Tab 2 7.0
? 6:01
https://www.youtube.com/watch?v=7sbgN0PxMzc
May 2, 2013 - Uploaded by HARD RESET KING
How to Hard Reset/Factory Reset Samsung Galaxy Tab 2 7.0Android 4.0 ... hi I got the same one as you and ...
Dec 21, 2015 | Samsung Galaxy Tab 2 7in. WiFi Tablet, 8GB
Hoe to change galaxy tab batery
I do not believe it is all that easy to take the back cover off. Depending on which model of the tablet you have you need special tools. A plastic picnic knife might be helpful but then there are a couple of screws to open as well.
The different models have slightly different process. See these sites.
Samsung Galaxy Tab 10 1 Battery Replacement
Samsung Galaxy Tab Battery Replacement
Samsung Galaxy Tab 2 7 0 Battery Replacement
Sep 02, 2014 | Samsung Galaxy Tab Tablet PC
To many pattern attempt
  1. With the Samsung Galaxy TAB turned off, press and hold the VOLUME Down button, and then briefly press the POWER button.
Note: If you see "Downloading" on the screen with an Android shoveling you pressed the wrong Volume key. Remove and reinsert the battery and try again.
It should hard reset any of these tablets:
Reset GT-P6210 Galaxy Tab Plus 7.0 WIFI
Reset GT-P6200 Galaxy Tab Plus 7.0 WIFI + 3G
Reset GT-P6810 Galaxy Tab 7.7 WIFI
Reset GT-P6800 Galaxy Tab 7.7 WIFI + 3G
Reset GT-P7310 Galaxy Tab 8.9 WIFI
Reset GT-P7300 Galaxy Tab 8.9 WIFI + 3G
Reset GT-P7510 Galaxy Tab 10.1 WIFI
Reset GT-P7500 Galaxy Tab 10.1 WIFI + 3G
Apr 15, 2014 | Samsung Galaxy Tab Tablet PC
To many patten attempts
Feb 10, 2014 | Samsung Galaxy Tab 2 7" 8GB Android Tablet...
My Galaxy tab 7.7 wont charge, I tried to charge it yesterday when the battery was still 50% charged but now it is down to 15% and my tab won't charged. I am using the original charger, please help!...
my mama said that mayb ur need a new charger cuz Samsung is sending me a new 1 and I think that\'s y. I hav a 7 inch tab 2 n I love it but it stop charging so I don\'t no whats wrong but im getting a new charger so its all good and guppy now :) ill keep u updayted cuz I think its the chargers falt not the tablets!! idk if not then ill just reset my tab and cry my eyes out cuz that sucks big time I meen really who wanna reset there tablet? not mee! but what the hell..mayb a new charger will help the little baby...
Jan 23, 2013 | Samsung Galaxy Tab 7.7 P6800 3G 16GB...
How to install a game on my samsung galaxy tab?
Well, there is a place called "Android Market" or similar.
If your desired game can be found there, simply download and install the game app and you can enjoy the fun.
If the game can't be found, or it requires a fee to play. You'll probably need to root the device. Here is a 1-click Android-Root solution for your reference.
Sep 07, 2011 | Samsung Galaxy Tab Tablet PC
I am using samsung galaxy tab. The OS update option is not available in the "About Menu". So, How can I update my OS? and What is the latest version of android OS? When I tried to install some...
Galaxy Tab is not running on OS 3.0 (Honeycomb), that is running on the Xoom only. Samsung would have to release an update for your Tab themselves. Google makes it available and only Samsung can make that decision.
Mar 10, 2011 | Samsung Galaxy Tab Tablet PC
Samsung galaxy tablet is not charging
Make sure you are using the AC adapter as the Tab cannot charge solely from a USB cable connected to a computer or similar. If it is still not charging, your device's battery or connector has probably failed and will need to be replaced.
Hope this helps, Alistair
Feb 23, 2011 | Samsung Galaxy Tab Tablet PC
Samsung Galaxy Tab 2 7.0 16 GB 3G Wifi Unlocked Black Logo
Top Samsung Tablets & eReaders Experts
Eric Rotmil
Eric Rotmil
Jerry Greenberg
Jerry Greenberg
Are you a Samsung Tablet and eReader Expert? Answer questions, earn points and help others
