Mackie Onyx 1640i Mixer Logo
A
Anonymous Posted on Feb 17, 2014
Mackie mixer will not work with windows 8
I upgraded my PC to Windows 8.1 and now my mackie mixer will not work. I cannot find drivers for the serial number of the mixer.
Ben Armstrong
Level 2:
Sergeant:
  • Expert 360 Answers
  • Posted on Oct 31, 2017
Ben Armstrong
Expert
Level 2:
Sergeant:
Answers
360
Questions
Helped
95521
Points
788
Well depending upon the mixer and windows version you may have issues. Windows 8 is a 64bit platform, your mixer may only have 32bit drivers (x86). Try visiting the mackie forum for your mixer.
4 Related Answers
Anonymous
  • 3 Answers
  • Posted on Jul 31, 2009
SOURCE: bad transormer in my Mackie 1202 20 watt mixer
how u hook up a mixer
Michial Gueffroy
  • 1140 Answers
  • Posted on Mar 27, 2010
SOURCE: i wood like purchase macki mixer consoles
Here is a link to buy online or find a dealer:http://www.mackie.com/products/1642vlz3/ I would also recommend this store:http://www.sweetwater.com/ Enjoy your purchase.
Fred Yearian
  • 5603 Answers
  • Posted on Aug 13, 2011
SOURCE: i have a mackie fx 8 mixer connected to two thump
Balanced audio interconnects (either XLR or TRS cables from the mixer and then balanced audio interconnects from the amp daisy chain inputs to the existing speaker inputs. If the amps do not have linked input jacks, then use TRS type WYE connectors at the inputs. Then use speaker rated cables from the amps to the passive speakers.
Anonymous
  • Posted on Dec 08, 2011
SOURCE: hook up mackie mixer to m-audio fast pro
111111111111111111111111111111111
Some of my microphone inputs stopped working
downloads.mackie.com load this bus driver file. use winzip to install.....have fun meder's tv service
Firewire inputs do not work
Check in the computer "Device manager" if a PC with windows, and see if there are any devices with an yellow "X" through them- the port may have an interrupt conflict.
Then check audio properties of the system to make sure the devices are selected and enabled, and their volume level is up- even if you are operating through the Mackie software console.
If a Mac- check the Chooser to make sure that input device has been selected.
I have a mackie fx 8 mixer connected to two thump 15 " speakers. i want to add a set of base non- powered speakers with power amp to my fx 8. what are the connections?
Where I find power transformer of mackie 1604
You should be able to get this directly from Mackie service. Please see the link below for the contact information. Please note that the exact model number adn serial number will be required to insure that the correct transformer is obtained. There are a few variants of the 1604,
Dan
Link: http://www.mackie.com/support/service/index.html
1helpful
Hi im sorry if this sounds a little dumb!!! last weekend while i was on a gig i tried to hook up my lap top to my mackie mixer (cfx12) but i wasnt able to get winamp to play through it, which channels...
With a stereo splitter cable that takes the stereo 1/8 plug of the computer into two RCA plugs you could go into the "Tape Input" of the mixer... OR take a 1/8 stereo splitter cable from the PC splitting to a pair of 1/4 inch plugs go into one of the 4 stereo input pairs on the mixer... like 7 and 8 or 9 and 10 for example.
Where can we find replacement faders for mackie 1604
See the link below for contacts either locally to you are from Mackie support directly. These guys are extremely helpful. Please have the serial number of the unit with you when you contact them. That will insure that the correct parts are ordered.
DAn
1helpful
I need 2 channel (sliders) pots for my Mackie 1604 mixer, where can I get them
The best way is to contact Mackie support directly. They are extremely helpful. Please note that these units are not the easiest to access. Extreme care must be taken when dis-assembling them to prevent damage to the internal cables. The contact information is listed below. Just follow the link and either send an Email or call them directly. Also, have the serial number handy as there have been a few mods in the lifetime of the 1604 model
Dan
Link: http://www.mackie.com/products/home/contact.html
1helpful
2answers
No volume control with 2 faders on Mackie CR1604 mixer
If all other functions work for those channels, the most likely problem is the fader itself. These can fail and operate more like switches rather than faders. Without witnessing the behavior, I can not state that for sure. While these mixers are not the hardest to work on, they are time consuming. The faders can be purchased from Mackie directly. If you need to have this repaired, any shop that repairs audio gear should be able to erpair this for you. Where are you located?
Dan
Top Mackie Music Experts
 Grubhead
Grubhead
Grand Canyon Tech
Grand Canyon Tech
ADMIN Andrew
ADMIN Andrew
Are you a Mackie Music Expert? Answer questions, earn points and help others
