sc363 is a yellow PCU error. Try replacing the toner cartridge and resetting the PCU. If the error comes back, you'll probably need to replace that yellow PCU.
replace the black pcu(drum unit). the life of the pcu(s) are 15k each(blk & col) . the machine will work but copy quality will reduce and the error will be there. replacing the cartridge has nothing to do with this error.
SC307 - Charge AC bias error [Y] (Level D Error)**
Symptom: The charge current less than 200 ìA is detected.
Possible Causes / Required Actions: • Defective charge roller • Defective connectors • Disconnected harness • Defective high voltage power 1 1. Check the connectors. 2. Replace the PCU for yellow. 3. Replace the drum positioning plate. 4. Replace the high voltage power 1.
** (Level D Reset Procedure) Turning the main switch off then on resets SCs displayed on the operation panel. These are redisplayed if the error occurs again.
Most of the time when I find this happening on a printer, not just Ricoh's it turns out to be the PCU (photo conductor unit). The color PCU is one unit and the black is a seperate unit. Hope this helps.
