Splendide 2100 Vented Washer-Dryer Logo
d
don beaton Posted on Feb 17, 2014
Drying cycle i have a blower motor that is not going full speed it shuts off half way through drying cycle,why?
Dryer is only 4 years old, was drying perfect one load, then the next its not drying. Takes 3-4 times to get load completely dry.
ELECTRIC Dryer no heat or little heat, or shuts down to fast:
Check your venting and lint basket. Check blower for lint build up and blower wheel obstruction., test by trying to turn the wheel manually by hand (should be easy) May have to remove cabinet or front/back plate to get to it)
Next check the heating element itself with a meter for continuity OHMS CLOSED CIRCUIT. If not its defective.
Check dryer Terminal block prongs both outside prongs should give combined 220, and 110 each if u check 1 outside & 1 center (ground) prong. Also check house electrical outlet for full voltage. 220 because if u only get half or 110 volts you will be able to run the machine which uses only 110 to run motor but not the heater which uses a full 220,
Check the thermal cut off, the cycling and the hi limit thermostats.
For continuity or OHMS. If no ohms or resistance they need replacement.
Lastly check your moister sensor. ( located inside the dryer door usually) Especially if machine seems to shut down early and clothes are still wet.
Test with a meter at room temperature and it should show continuity.
A failed moisture sensor will affect the dryer run time in the automatic moisture sensing cycle but it will not affect the heating of the dryer or the timed cycle.
Feb 16, 2015 • Dryers
Dryer does not always fail to heat throughout entire drying time on timer.
Next check the heating element itself with a meter for continuity OHMS CLOSED CIRCUIT. If not its defective or has a short if its grounding out? Which in turns causes blown fuses or thermostats or overheating.
In some dryer's the control panel relies on a thermistor rather than a CYCLING thermostat to regulate the drum's air temperature by monitoring the component's resistance changes; resistance goes down as temperature increases and up when temperature decreases. Once the drum's air temperature reaches a certain level required to dry clothes, the control panel shuts off the heater. The panel will turn the heater on again and begin another heating cycle when the thermistor indicates that more heat is needed to keep the air temperature constant inside the drum
A failed moisture sensor will affect the dryer run time in the automatic moisture sensing cycle but it will not affect the heating of the dryer or the timed cycle. Which are reflected by the thermostats.
Read more :http://www.ehow.com/info_12203962_check-dryer-thermistor.html
Oct 17, 2014 • Dryers
My Maytag bravo Dryer is not drying my clothes correctly. The timer on the dryer keeps going up higher indicting it needs more time to dry?
Oct 13, 2014 • Dryers
My danby dryer keeps shutting off and turning on and the clothes take forever to dry
GOD IS STILL GOOD !!!!
What does it mean if I my drying system keeps shutting off before the clothes are dry?
1helpful
I recently tuned up my blower. It starts great but if I turn it off Nd try to restart it it floods and will not start until I let it sit for awhile.
If the engine is warm and you shut it down, leave the choke off, lower the revs and start it. (when the choke is wide open you are using the fresh air coming in to dry the spark plugs and prevent flooding). If the motor is already flooded use that procedure to dry the plugs, then go back to full choke until it tries to start and quits again, then use half choke and pull one more time... works all the time.
1helpful
2-cycle blower starts up but wont run full power rpm
Have you tried choking it about half way and see if that helps? Does it do the same after it is warmed up?
5helpful
2answers
Gas leaf blower runs at half speed
First you will have to get a carburetor kit ,it consists of diaprams and inlet needle,you then remove the two srews that hold carburetor on the engine and remove gas lines,also the throttle cable remove screws that hold ends of carburetor on under these you will find the diaphrams and needle remove these be carefull not to loose the little spring under the needle lever.
!get you a can of carburetor cleaner and spray carburetor the blow it out with air you will notice little jets in carburetor that have to be clean use a wire from a bread tie to clean them out install new gaskets and diaprams in same position you took old ones off.you can also look at carburetor to see what kind it is walbor,zama,tilloson? type the name in google search and can get a diagram of carburetor if you loose your place,or just ask me.
Goodman heatpump
I think your run capacitor for the blower motor needs replacing.
If it goes out the motor will not develop full speed and will shut off on it's internal thermal protector. When it cools off it will kick back in until it gets hot and shuts off again.
The motor may be dragging and have to be replaced, but I would try the capacitor first.
Post back with any questions.
Thanks/Mike
Top Splendide Washing Machines Experts
ADMIN Andrew
ADMIN Andrew
David Kassin
David Kassin
Are you a Splendide Washing Machine Expert? Answer questions, earn points and help others
