Re: Need security code for becker le mans 30, model...
Hi Frikkie,
Although the car radio models are the same the codes are all different. the only way to get the code is to contact the car dealership from where the car came from.
61633 is the code ,as for the wiring well thats simple enough just look carefully at the wires and seperate the speaker wires from the feeds the earth will be the chassis of the radio or often the aerial wire as the as the outer sheaf is earthed .It will have two feeds one a permanant 12v memory and the other a ignition feed 12v for on and off with the ignition key
The radio SERIALNUMBER will be required for calculating a code
On some radios, pressing Buttons 6 and 1 or 6 and 2 (together) maydisplay a Serial Number
If not , then removethe radio from the dashboard.
Then post all the letters+numbers on any labels,barcodes or stamped inthe metal casing.
This information canthen be used to see if a code can be calculated
