Washing Machines Logo
b
brenna_schul Posted on Feb 17, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Kenmore 2600 TOP LOADER smells like Mildew. I can hear water sloshing around under drum. Is that Normal?
My Kenmore 2600 TOP LOADER smells like mildew. I've done the bleach cycle a couple of times and the mildew smells returns in a couple of days. I leave the lid open after each load to let the drum dry our. When the drum is empty, I can move it around and I hear water sloshing around underneath it. Is the water sloshing around normal? I've read that other brands have a liquid filled tank to help balance the drum. Does Kenmore? What could be causing the mildew smell? I've read that this Kenmore probably doesn't have a lint trap, but should I still clean out the drain? If so, How do I access the drain?
Level 3:
  • Kenmore Master 19,187 Answers
  • Posted on Feb 17, 2014
Kenmore Master
Level 3:
Answers
19187
Questions
0
Helped
4340555
Points
82259
The drain on all washers have this issue. Unless the drain hose runs down hill, when the pump stops, water runs back into the machine that was in the hose but was not drained.
  • 4 more comments
  • brenna_schul
    brenna_schul Feb 18, 2014
    Thank you for your help. Do you think that the leftover water is causing the mildew smell? Or should I check out the drain pipe? I've had it for 2 years and the mildew smell just started recently.
  • Brad Brown Feb 18, 2014
    What is the whole model number?
  • brenna_schul
    brenna_schul Feb 19, 2014
    Kenmore Model Number 110.2600.2011
  • Brad Brown Feb 20, 2014
    http://www.searspartsdirect.com/partsdir... WASHER&blt=11&shdMod=&keyId=
  • brenna_schul
    brenna_schul Feb 20, 2014
    Thank you, I will check that out.
  • Brad Brown Feb 26, 2014
    I just read that there is a class action lawsuit over this very thing. Your washer is listed in that. The comsumers are suing because of the issue. It went all the way to the US supreme court to deny class action status. The supreme court said no to disallowing it as a class action.
5 Related Answers
Anonymous
  • Posted on May 29, 2008
SOURCE: smells of mildew and so do clothes
There is another product out there that seems to work real well.... it is called "AFFRESH" and it is for He front load washers... Its available at Lowes for about $6.50
Anonymous
  • Posted on Oct 01, 2008
SOURCE: mouldy mildew smell
I had the same problem and I fixed it fairly easily in about 45 minutes:
The root-cause is the incredibly stupid design of the plastic ring that snaps over the plastic wash tub. It is filled with many nooks and crannies that rarely contact the wash water, thus getting scummed up and moldy. See a picture of the gross mess here: http://www.falselaborblog.com/2008/08/moldy-maytag.html
The fix involves opening the top (easy) and removing the ring (fairly easy) and can be done yourself if you are the least bit handy.
Unplug the unit.
***If you are mold-sensitive, wear gloves and breathing apparatus or have someone do this for you.***
Tape the lid shut so it doesn't flop open when you raise the lid.
Use a putty knife to push into the front seam about 1 1/2 inch from each corner. This unlocks the top and it will open just like the hood on a car. Carefully secure this in the open position and don't let it fall on your head or your hands.
You will see plastic fasteners holding the top ring around the outer plastic wash tub. These will unsnap (you may need a flat-head screwdriver for some of them).
Carefully lift this out and try not to puke when you look at the underside (see photo http://www.falselaborblog.com/2008/08/moldy-maytag.html). Take it to a laundry tub or bathtub and thoroughly clean it by scrubbing with hot water, detergent and bleach.
Before replacing the ring, use a thin brush to clean between the upper part of the wash tub and drum---the scum and mold will be in here also.
Replace the ring in the reverse of the above steps.
Prevention: There is none. You will have to do this every 4 to 6 months to prevent mold from infesting all of your clothing, etc.
I'm experimenting with limiting wash load size to "large" and never using "super", reserving the "super" setting for running periodic (hot water + Clorox) to see if it reaches the idiotic upper ring and keeps it clean. I am not hopeful that this will eliminate the need for these overhauls.
P.S.: The person that designed this washer should have all of his/her underwear and bed linens washed in an uncleaned Maytag Atlantis for life.
docjohn174
john gagnon
  • 943 Answers
  • Posted on Oct 09, 2008
SOURCE: Clothes smell like mildew
HI thanks for your question. My solution is 1 cup of vinegar, per wash load. In time, will solve your problem.thanks the appliance doc. please rate my answer. thanks.
Anonymous
  • Posted on Jun 08, 2009
SOURCE: mildew smell in front loader
Yup! I have the same issue with a WE206BNW (Canadian model). Did the same thing - dried the water off the door and leave the door open when not using it. Sort of helped, but then I ran an empty light load with bleach through it - no clothes, just water. Helped a lot.
Henkfish
Paul Flynn
  • 34 Answers
  • Posted on Oct 11, 2009
SOURCE: Our towels and clothes have a mildew/musty smell.
Towel mildew odor is transferred from the washer to towels and clothes. The washer must be cleaned first. After cleaning the washer and towels washing habits must change to stop mold smell from returning.
Washing machine mold / mildew is caused by:
#1 cause is overuse of detergents. Detergent companies are notorious for instructing to use too much detergent. Especially with soft water or when using liquid detergent no more than 1 tbsp of any detergent should be used.
#2 most common cause is using fabric softener because it's dispensed in the rinse cycle and will coat the inside of the outer tub with residue that is a food source for mold to grow.
#3 using only cold water for washing is fine but makes preventative maintenance very important. A weekly hot soak will dissolve odor-causing residue from inside your washer.
#4 not using the washer. If the clothes washer isn't used very often maintenance is especially important. If leaving for a vacation it's a good idea to clean your washer. Do a search to "remove washer odor" to read just how big the problem is. There are all natural washer cleaners that will also remove mildew odor from towels and clothing after the washer has been cleaned.
When you spin the drum around it makes a sloshing sound
Your unit is not draining correctly. The mold and musty smell you notice is a result of that water becomning stagnant that that is not being pumped out.
The repair manual 16010061.pdf states to check the drain for restrictions. After that if there are no restrictions you check the pump motor for 18 Ohms across the winding terminals. The final step is to change the pump.
Here are the steps for cleaning the pump:
CLEANING THE PUMP
The pump assembly can also be disassembled without removing the hoses from the pump
(See Figure 6-6). Not included in post
1. Depress the locking tab on the face of the pump housing. Top Rh front of rectangular box on pump body side.
2. Rotate the block portion of the pump containing the motor windings toward the front of the washer. This will disengage the locking tabs of the pump housing from the pump face.
3. Carefully remove the pump body away from the housing. The drain impeller is exposed for cleaning.
Thanks for using FixYa.
Kelly
1helpful
There is water left under the tub after the wash is over. When I move the tub I can hear the water sloshing. How can I get rid of the water. It makes my towels smell like mildew.
If it is draining down and spinning the clothes dry then all of the water is draining out. There is only about a 1/2 in space under the tub. There is a balance ring around the top of the tube that holds water. That may be the sound you are hearing? Try washing a load without anything in it on hot and use a box of baking soda. See if that will help with the smell. My washer leaves a mildew smell sometimes. I started running an extra rinse cycle on it. And that helped. I think it was my water.
We get a bad smell and even after the macine stops when you turn the drum by hand you hear a lot of water sloshing around.
what you hear is liquid in balance ring that is normal.
go to appliance parts store ask for tub cleaner product
2helpful
2answers
Problems with mildew around the rubber and terrible odor to the laundry after washing. Also, hear water sloshing when turn the drum by hand.
Front loaders are known for building up mold and the smell.
It’s caused by using liquid detergent which is made from animal fat. Use powder. And use the minimum amount.
It’s caused by using fabric softener. Dilute it 50/50 with water.
It’s caused by the water remaining in the tub between washes. Leave the door open to allow it to dry. .
Pull the rubber door seal back and clean the mold off .
Water between the drum even when not on
Water between the drum is a common problem with not only front load but top load as well.
Front load washers such as the neptune have an airtight/water tight door which will hold moisture in the machine when closed. Try opening door and keep open between loads. In addition, a monthly cleaner specific for the front load machine will help this problem
2answers
Laundry smells like mildew after washing
Front load washers retain water that you cant see or get to. There are cleaners for washing machines available. I clean mine every month with alot of bleach , try pouring a half gallon of bleach in the soap insert on a normal wash cycle and an extra rinse would not hurt no clothes of course.
3helpful
3answers
Kenmore Elite HE 3 front loader--water standing under drum at all times?
If you take off the bottom panel on the front of the washer, there is a little pump with a twist lid on it. Open that and see if there is anything plugging up the drain. We had a problem where a sock got sucked into it and it did the same thing.
Washer won't drain completely
water sond when tub is spun by hand is normal. there will always be wa terinside machine betwen tubs, maytag even uses a waterfilled tub ring for counter balance, totlly normal to hear. as far as mildew smells, use www.affresh.com
Alexander
vince
