SOURCE: drum on model 1510 Kyocera copier
1-6-4 Image formation section
(1) Detaching and refitting the image formation unit
Follow the procedure below to replace or check the image formation unit.
Prucedure
1. Pull the drawer out and open the front cover, bypass tray and paper conveying unit.
2. Remove the waste toner tank and toner container.
3. Remove the two screws holding the waste toner tank cover and then the cover.
4. Remove the screw holding the developing retainer and then the retainer.
5. Remove the two screws and datach the connector and remove the image formation
unit.
Developing retainer
Image formation unit
Connector
SOURCE: can you help with kyocera cs-1820
Look in the Document Processor, That is the auftomatic feed device.Look for a scrap of paper jammed in the machine.Try using a dustblaster(canned air) to blow the debris out of the feeder.something in the feeder is operating the switch that detects paper in the feeder.Good Luck
