Up until yesterday I could synchronize my HTC Topuch HD with my PC using activesync and USB cable. I have since not been able to achieve the connection. another HTC phone that I have does sync fine using same cable and computer. I have reset both the PC and the Phone to no avail. I can sincronize fine over the GPRS conection and can get my e mail etc. However cannot down/up load files thorugh the USB connection since it does not kick in the computers active sync.
SOURCE: activesync download
this should work for you. http://www.microsoft.com/windowsmobile/activesync/activesync45.mspx
SOURCE: Vodafone Live GPRS active, but not able to connect the web
vodafone live setting for windows based mobiles version 6::::
select "start" ---->>> select "settings" ------->> select "connection"----->>> select "connections"
Now Select "Add a new modem connection"
Connection name::"Give any name"
Moden:: select "Cellular line (gprs)"
Select "Next"
Access point name:: "portalnmms"
select "Next"
Username:: (blank)
Password:: (blank)
Domain:: (blank)
Select "Finish"
Now Select "Setup/Edit my proxy server" below that "Add a new modem connection"
Select the two check boxes
1.) This network connects to the internet
2.) This network uses a proxy server to connect to the internet
Now you ll have proxy server box below that you will have "advanced"
Select "advanced"
Select "HTTP" --->> Server:: "10.10.1.100" port:: "9401" select "ok"
Select "Wap" ---->> Server:: "10.10.1.100" port:: "9201" select "ok"
Give ok to all options.
Now select "start" select "internet explorer" and try it for the connection...
When internet is connecting it ll show "Connecting to GPRS"
You ll be getting "locating" and "opening" and the webpage
SOURCE: same problem
for xp you need ActiveSync 4.5 and for Vista WMDC6.1. also in connection under USB to PC uncheck Advanced conection.
