There is a paper jam that is unaccessible from outside the printer.
Here's a video of how the printer is taken apart. I hope this helps you:
There is not a lot that you can do to take these apart. You can start by removing the paper tray. It should pull straight out.
There is also a release to open the printer up. This gives you access to the ink cartridges. You should not see any paper from this perspective but there is a chance that there will be some paper stuck there.
Where is the "release" to open up the printer MX922?
SOURCE: my canon mx310 keeps showing a paper jam alarm and there is no paper jam. how do I fix it?
give this a try
alternative :
Load
a piece of thick paper, for example photo paper and press the resume
button (may be diffrent button on diffrent models) a few times to the
printer picks up the paper and puts it through the machine.
SOURCE: Canon MP140 paper jam error with no paper jam
try this
alternative :
Load
SOURCE: Canon D880 Printer/Fax
1. Take off 3 plastic covers one above exit area-slide top to left to access screw
remove lower exit cover and side cover -unsnaps with 2 pins and there is one more cover I think over the fan that needs to come off.
2.Locate black plastic sheet covering a circuit board carefully pull this back-disconnect 3 plastic connectors that lead from the heater to the circuit board
3. using a offset phillips #2 screwdriver remove 3 screws that hold the fuser to the frame. carefully lift fuser up and out toward the exit area.
4. pop off black cover remove 2 screws from top of fuser, disengage cover lid locks with a small screwdriver, lift upper fuser heater-be careful NOT to damage
plastic heater membrane. remove paper jam and reassemble.
SOURCE: My Canon PIXMA Pro9000 InkJet Photo Printer paper jam error
Had the same problem with mine. Shook it upside down and cleaned it with air cans after reading this solution for other canon printers:
http://www.fixya.com/support/t119769-false_paper_jam_warning_canon_pixma
To my surprise, it worked perfectly... and was great stress relief.
SOURCE: My canon ip2600 printer has a paper jam error, but there isn't.
Hello there
You may not see a paper jam.
This may work for you, it has worked for many here I given this advice so gave it a try it could work for you.
Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Also clean The purge unit, called a spittoon assembly in an HP, Lexmark, Caonon and other inkjet printers, is where the print head assembly parks when not in use, also its other job is to clean and make sure the print head is clean and open for printing.
That is where you'll find the print head assembly parked on top of it.
It also has an electrical pump to milk the print heads and test for ink flow.
So clean all under where the heads are parked and on IP6600D models you can take out the heads just by clipping them out, and then clean well.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
CAUTIONSee Also Cause 3. Is the ink tank properly installed? Summary If the ink tank is not properly installed, it interferes with the operation of the print head.
When removing the jammed paper or foreign material, take extra care so that you do not touch the inner parts. Or, it may cause another printing problem.
CAUTIONCanon PIXMA MX922
Always remember "Do not touch the Print Head Holder while it is moving."
Wait until the Print Head Holder automatically stops.
Do not even attempt to stop/move the Print Head Holder by holding it.
