Hitachi H45MR 12lb. SDS Max Chipping Hammer Logo
A
Anonymous Posted on Feb 18, 2014
Zw220 hitachi recommended transmission oil - Hitachi H45MR 12lb. SDS Max Chipping Hammer
What happens if I don't use the right transmission fluid for chevy malibu 2003
need to know the transmission type --manual or automatic
for manual most recommend a light weight mineral oil but experience shows 80-90 gear oil the best
for auto
stick with the recommended atf for your model and it it is a CV transmission --only the recommended oil as atf will damage the box
I have a 2005 Klx110 that is very, very hard to shift when I first start it up, but after about 20 mins it shifts fine. Adjusted the auto clutch which helped a little... any thoughts?
the transmission and clutch oil should be different to the engine oil
check /change that oil and only use the recommended transmission oil
Apr 25, 2018 • Motorcycles
Transmission
There are two types of transmissions in 1991 Toyota Corolla. Manual Transmission and Automatic Transmission.
1. Manual Transmission:
The transmission oil is checked through a level bolt which is provided to the left CV joint side in the middle of transmission. To check the oil level, park the car on a level floor, remove the level bolt with 22 mm or 24 mm spanner. If the oil starts coming out of this hole the oil level is considered OK. If not, top up the oil till it starts coming out and tighten the bolt. The recommended manual transmission oil grade is 75W/ 90W and total capacity is 2.4 Litres.
2. Automatic Transmission:
Warm up the engine, park the car on level floor, pull up the hand brake, gear lever stick in P, keep the engine start, let the radiator fan come on, take the auto-transmission stick out, wipe it with a clean dust free cloth, insert it in, again take it out, keep the stick in horizontal position and check the oil level. At operating temperature the auto-transmission oil level should be at upper level (Hot). If not, add oil to mach the mark. The recommended auto-transmission oil is Automatic Transmission Fluid (ATF) Dexron II, and total (drain and refill) capacity is 1.4 Litres.
What type of oil do they use and how much in your cb75f bandsaw wheel bearing oil filler tube
I can't recommend you any type of oil. You should check your manual for recommended oil or you may want to call the manufacturer of your band saw.
1helpful
Where to add gear oil to manual 2002 kia sportage
For a manual transmission, an SAE 75W-30 transmission oil is recommended. For an automatic transmission, Dextron II E or M-III is recommended. The 2002 Kia Sportage hold 2 quarts of transmission fluid. It is recommended that these fluid levels be checked every six months and changed or refilled as needed. The fill spout should be on the left side of the engine block and the fluid will be red in color.
1helpful
Should I have the oil in transmission changed?
I would not go by the oil change company recommendation.
It's much better to go by the car manufacturer's recommendation. Look in your owner's manual for the recommended time/mileage to change the transmission oil and filter.
3helpful
2answers
Oiling a hitachi gas nail gun
Hi Andy,
If you're asking what to oil and when, here you go.
Every day before using it, oil the hammer and slide mechanism. Also put several drops into the hose connector. This extends the life of the seals. You should use a light machine oil.
Hope you find this to very helpful
Mike
Looking for when the oil and transmission should be changed on Lt
Hey,
Many manufactures recommend a engine oil change every 50hrs more often in extreme conditions,
Most transmissions are sealed units if this is the case company's recommend not to touch these,
If you have a hydrostatic drive or a Zero turn unit with twin hydrostatic drives the transmission oil must be changed every 500 hours or every year whichever comes first as the hydraulic oil brakes down in time, also at these intervals the hydro oil filter must also be changed...
Brad:)
1helpful
Oil change
well its always recommended every 3000 miles to change the oil if you are using mobil1 full synthetic oil then every 5000 miles transmission i recommend every 45000 miles 60000 mile should be radiator fluid,power steering,fuel filter if trans hasnt been done then transmission
Top Hitachi Hammering Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a Hitachi Hammering Expert? Answer questions, earn points and help others
