SOURCE: LG 1710b tft monitor - no picture. screen shows 4 hozizontal line
Problem with Interface board or panel.
Also maybe due to defective powersupply filters.
Samir
SOURCE: LG Flatron 795FT Plus - horizontal lines on screen
YOU NEED TO CHECK TO SEE IF THE CAPASITORS ON THE POWER SUPPLY AND MAKE SURE THERE NNOT BULGED OUT OF LEAKING IF THEY ARE THE NEED TO BE REPLACED
YOU SHOULD BE ABLE TO FIND EVERYTHING YOU NEED AT RADIO SHACK FOR LESS THEN 20 BUCKS
SOURCE: LG - L192 WS LCD Monitor displays blue color
it isnot softwere problem. we can not solve in home. lcd graphi can be reset.which we can get in net it can be solved by expert. once atime i get it in web side, t
SOURCE: Color patching
And move it away from the magnet or speaker :) Speakers are cookie monsters for screens.
SOURCE: blue verticle line is displayin
The blue line is most likely the result of your monitor's screen going bad. One thing you can try is disconnecting and re-connecting your video cables to make sure it's tight and has a good connection. This probably won't help, but it's worth a try. You may also want to connect the monitor to another computer to see if the blue line stays, or goes. If the blue line stays with another computer connected, the problem is inside the monitor. If the line goes away, you should replace/repair your computer's video card and/or cable. Otherwise, you need to replace/repair your LG monitor.
