Tablet did not boot at all. Opened the device (four screws and multiple clips) and saw that a ribbon cable had worked loose. Reattached the ribbon cable and secured it. Attempted booting. Now, at least the "infoTMIC" logo appears, but the device does not boot from that point onward.
Tried the "reset" button on the back. Attempted to boot. Stuck on boot logo.
What's my next step?
(will not charge or power on)I sent my smartphone in for repair the other day.They told me it was water damage in the charging point i have never had it near water but apparently having the phone in high humidity places is common for it to happen eg talking on phone under bus stop in the rain, having phone somewhere in bathroom while having shower, holding phone over hot coffee? hope you get it fixed :p
Depending on which version you have please see the following notes:
How To Factory Reset/Recover the systerm On Your Tablet PC(Flytouch 2/SuperPAD 2/Infotmic tablet 2)
1. Press "Power" and "Home" button at the same time, hands off until you see the words on the screen.
2. Select:"wipe data/factory reset" with the "volume" button, and then press "menu" button.
3. Select:"Yes -- delete all user data", and press "menu" button.
4. Wait until you see" Enter erase_cache Data wipe complete" .
5. Press "reset", calibrate it and set the language.
How To Factory Reset/Recover the system On Your Tablet PC(Flytouch 3/Flytouch 4/SuperPAD 3/Infotmic 3)
1. first press the "MENU" key, keep pressing the "MENU" key while you press the "POWER" key, remove your hands when you see "recovery" from the screen.
2. Wait a few seconds until it is done. And then the system will start..
Precautions
A power failure during the firmware writing operation may disable the tablet PC.
* Use a fully charged Battery or dedicated AC Adapter for the firmware update.
* Do not shut off the power during the firmware writing operation
In order to hard reset your Samsung tablet, the steps given below must be followed:
Ensure that the Samsung tablet is powered off.
Press the Power and the Volume Up button together till the device displays the start-up logo.
Once the logo is displayed, release the buttons and wait till the device enters the Android system recovery mode.
On the displayed screen, use Volume Down button to go to the wipe data/factory resetoption (Volume Up and Volume Down buttons are used to highlight the displayed options on the Android system recovery screen).
Once the option is highlighted, press the Power button to select the option. (Pressing thePower button in Android system recovery mode selects the highlighted option.)
On the next screen, press the Volume Down button multiple times till the Yes -- delete all user data option is highlighted.
Press the Power button to hard reset the Samsung tablet device while clearing the dalvik cache along with the process.
You need to do a factory reset by holding down the power and the volume (-) down button at the same time until u see a black screen with Command prompts.. After this use the volume up and down buttons to stroll up and down and the power button to select.. Go down to data factory reset and press select then select yes.. And your tablet should reset itself.. This May or may not work on the first try.. Please wait at lease 5 minutes for it to boot up because it will take a while to boot after this so don't get all frustrated. If it's still stuck at the go logo just go back to step 1 and repeat.. This is what I did for my tmax 9 tablet when it was stuck at the go logo.. It didn't work the first ten for me but for the 2nd factory wipe it did the trick..
To download apps for an Android device, you need to have (or create) a Google account - if you have a Gmail account, it is this same account.
Then, you have to search in your tablet apps for the Google Play app and touch on it. Entering Google Play, sign in using your account and you will be ready to download your apps.
NOTE: to enter your Google Play, you will need to have the Internet connection active and correctly set up in your device.
You'll need to do a factory reset: 1. With the device off, press and hold Volume Up and Power. 2. Release the Power button when you see the logo, but continue to hold Volume Up until the recovery screen appears. 3. Use the Volume buttons to navigate the menu and select wipe data / factory reset. Press Home to choose the selection. 4. Press Volume Up continue.
If you have available at your home, try spraying just a little bit of WB40 in the button and try to move it back to its place depressing it and dragging it back with two matches or two toothpicks.
