Go in to function mode (function + original size + 3 at the same time). Go to F7 for counters, find the fuser web counter and set it to 240,000 to reset it. Set any other counter alarms that go off to 0. The maintenance period is supposed to be 240k copies, but from the factory it comes set as 120k so you can change that if you want.
"TEL FOR P/M" means to call for preventive maintenance. A technician needs to come and perform preventive maintenance for the copier and reset that setting.
Panasonic does not publish a way for end users to do their own preventive maintenance or reset that counter. There is a hidden service mode to reset the counter, but if you do that without perfroming the required maintenance, you could end up with trouble down the line.
A circle with dots around it indicates that the machine requires a developer change.
This should only be carried out by an engineer but you can still use the machine whilst this status light is up.
A red man indicates that a routine service is required.
The drum counter reaches 25000 copies , it's time to change the drum and reset counter .
Enter the reset mode by pressing : # - * - c - * .
then press : 20 - start -01- start - CA - CA .
Hope this will help .
Hello, these machines needs to be connected to your network and correctly configured in order to scan. Once that is done you need to install a program called Panasonic Communications Utility which can be downloaded from www.panasonic.net. When the program is installed on your pc a blue tray will appear on your taskbar next to the time. Click on the tray and enter a name for the panasonic machine to identify you. Now go to the DP-3030 and press SCAN, scroll down with the arrow key until you see your name, set the document you want to scan and press START. A popup display should appear on your pc notifying you of the scan. If your name does not show switch the DP-3030 off and back on again and wait a minute or 2 for the machine to find your name. Thank you.
If i understand the question your copier is in service mode. To get it out of service mode press stop a few times and press and hold the function button then press clear button.
