I want to trigger PL2303 Bar code scanner from Android app.Which command I should give to do this.
SOURCE: My RS-232 scanner beeps at the bar code but nothing appears on-screen.
The "Beep" just means that the scanner has been presented with a valid barcode. (nothing more) The scanner has probably not been set up correctly as this is a common issue. the settings need to be set correctly for your environment. you should have a code book with some bar codes in (part of the manual) which can set all the options within the scanner, There is an option to recall defaults here is the electronic manual ftp://ftp.metrologic.com/pub/download/productmanuals/00-02544.pdf
SOURCE: barcode scanner for Verifone Omni 3750
http://www.allthingspos.com/assistance/drivers.htm Here u have if u need manuals or driver SLOVED???
SOURCE: Barcode scanner keeps reverting to internal utility
You could delete this utility if you are not using it
SOURCE: Barcode printing on using Code V on IBM 4232
SOME OF THE COMMUNITY COLLEGE IN OUR TOWN STILL USE COBOL IN THERE NETWORKING, LOOK IN YOU PHONE DIRECTORY FOR ANAMATED SULATIONS, SOME PLACE MAYBE HELPFUL IF COMPTER USERS GROUPS, COMPUTER CLUBS, I LIVE IN MESA AZ AND THE BOY SCOUT OF AMERICA HAVE A COMPUTR SWAP MEET EVERY LAST SUNDAY OF EACH MONTH AT SCOUTSDALE COMMUNITY COLLEGE YOU MAY BE ABLE TO CONTACT THE BOY SCOUT TROUP LEADER AND ASK FOR ASSISTANCE IN THIS MATTER HE MAYBE ABLE TO HELP YOU 1-480-423-6000
ROD
SOURCE: carriage return before barcode
The barcodes you need are the following from the product reference guide.
Scan options.
<DATA><SUFFIX>
Enter.
If you can't find them, feel free to email me and i can provide them for you.
I solved the problem. I managed to get that command which triggers scanner.
Issue solved.
