Question about Westinghouse SK-32H240S Television
Westinghouse UW39T7HW CAN I HOOK UP EXTERNAL SPEAKERS TO MY TV
I have a westinghouse tv vr-6025z and I want to hook up external speakers.
most set have jacks marked "audio out" which could be RCA type jacks, or a coaxial or optical output . Connect a cable or cables from whichever one of those is compatible with the inputs on the back of your stereo receiver.
Dec 22, 2016 | Westinghouse VR-6025Z 60" LCD TV...
How to hook up external speakers
There is no direct port to hook up external speakers. you have to use an amplifer to get connected in between TV and amp, using an AV cable.
Sep 29, 2012 | Magnavox 47MF439B 47 LCD TV
How do i hook up external speakers to my sanyo plasma 42 inch hd tv
if there are jacks in the back of your sanyo you can hook up 2 speakers if your sanyo do not have external audio RCA jacks for speakers...you will need a home entertainment receiver to hook up the 2 -7 speakers...
Jun 21, 2010 | Sanyo PDP-42H2W 42 in. HD-Ready Plasma...
How can I hook up external speakers? I have
Go to your tv menu, and make sure that your fixed audio output is selected not variable. Variable will make not work, with the television volume is turn down. When you hook the speakers, make certain that it is on a fixed audio out, not variable, as well.
Oct 27, 2009 | Zenith C34W23 34" TV
Is there anyway to hook up external speakers to the tv? Like a surround sound system? computer seakers?
there is no audio out in my proscan 32LB30Q tv so there is no way for me to hook it up on my amplifier....
Sep 11, 2009 | Proscan 32LA30Q Television
No sound from external speakers system
Look into your monitor settings and computer settings and see if you can reverse the "input" and "output". If both are set to line in or line out then they pretty much cancell themselves out.
May 23, 2009 | Televison & Video
How can you hook up external speakers to this TV?
youhave to have an audio reciever or powered speakers to do so
May 20, 2009 | Proscan 26LB30QD 26 in. LCD HDTV
Want to add an external speaker to TV
If you have audio out RCA jacks then you can hook up some computer speakers that have RCA jack inputs. If you don't have audio outputs and your TV has a HOT chassis then you won't be able to do it. If your tv has a switching power supply then you can install a jack to TV speakers, so they disconect when you hook up your other speakers, if you try and hook up speaker to the TV speakers then the impedence will change, and your audio output IC will get hot and short out.
Oct 26, 2008 | Televison & Video
19 inch LCD TV
Hi, Chances the Audio L/R are line level (can not drive speakers) other than they can either be output or inputs. If they are inputs, they are connected to a source such as a DVD player or if they are outputs, connects to an external amplifier where external speakers maybe connected. hope this be of some help/idea. Post should you need additional information. Good luck and kind regards.
Aug 25, 2007 | Westinghouse LTV-19W3 19 in. LCD...
Televison & Video Logo
186 people viewed this question
Top Westinghouse Televison & Video Experts
CoppellTVRepair.com
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
