Pacific Image PrimeFilm 1800u Film Scanner (35 mm) Logo
H
Heribert Weiss Posted on Feb 21, 2014
Driver windows 7
Scanner needs driver update from win 98 to win7
Console Centre
Level 1:
New Friend:
  • Contributor 24 Answers
  • Posted on Apr 03, 2014
Console Centre
Contributor
Level 1:
New Friend:
Answers
24
Questions
0
Helped
3302
Points
36
Look for make and model of scanner and see the manafactures website support section.
Hp 6500a wont scan in win7 32bit
Make sure you have installed the scanner drivers for win7. I have the same printer and I can print & scan from Win XP, Win 7 & my iPad (All on wireless). Drivers for the printer & scanner must be installed.
1helpful
2answers
Had win8 went back to win7
Drivers can be found here:
http://www.dell.com/support/drivers/us/en/19/Product/inspiron-15-3521
You probably need the Network & Chipset drivers, but make sure you get the right ones for your model.
2helpful
3answers
Looking for driver MF5630 canon Win_64
I have spent hours to find a solution... there is no driver. But there are definitely 2 solutions:
1. MF5630 - using ONLY printer in Win 7 x64:
You have to use the drivers for MF5700 Series - http://driverscollection.com/?file_cid=4213082682609f383f81540957d
- http://www.techulator.com/resources/4156-How-add-Printer-manually-your-Windows.aspx
1. First, Click on the Start button in your screen, further click on Control Panel button and then double click on Devices and Printers button.
2. Then click on Add a Printer button in the menu.
3. Further select the Add a local printer button from the available menu.
4. Then choose an existing LPT port and click Next button .
5. Further select the correct driver from the driver list menu for your printer. Suppose if the requisite driver is not available then click on the Windows Update button. After the Windows 7 Update installation finishes in your computer, once again search for the appropriate driver for your printer.
2. FINAL SOLUTION - for printer and scanner - if you have proper PC configuration:)
Win7 has a possibility: http://windows.microsoft.com/en-us/windows7/install-and-use-windows-xp-mode-in-windows-7
you can install the WIN XP environment where you can easily install driver for Canon MF 5630 (or any other by Win7 x64 not supported printer/scanner) and additional software.
BUT YOU NEED to run: Windows 7 Professional, Enterprise, or Ultimate editions. Windows XP Mode is not supported on Windows 8.
Your BIOS must support Virtual Machine.
2helpful
Installing scanjet 4200c to windows 7
no updating driver for this scanner it can only be use in win xp bot if u can only manage it with win vista bot it cant work with win7
Upgraded my Gateway FX400X desktop to Windows 7 from Windowx XP... Reinstalled my HP Photosmart D5160 printer and despite being connected to the computer, the computer will no longer detect a...
did you find and install win 7 drivers.?
was win 7 a clean install?
win7 is not supported by Microsoft or driver suppliers anymore/ you probably won't be able to get any win7 updates either this late in the win7 game
I am trying to install philips soft ware on to my computer but i am promted with "sorry your system is not supported" i have windows 7, the program only supports windows 98 se, me, win 2000 and...
You can check on the philips site if they have Win7 drivers or install it by right click op the install file (exe\msi) and choose "compatibility mode" .
I need driver (benq Scaner 4300) for win 7
HI!
Your scanner is not compatible with Win7 yet, no updated driver online.
Click HERE. and check from time to time for the updated driver.
Hope this helps.
16helpful
3answers
I need driver for microtek scanmaker 3840
you can download it from
http://www.driverskit.com/freedownload/Scanner/Microtek/ScanMaker_3840_3830_3800_ScanWizard_5_5_93/14515.html
6helpful
2answers
Top Pacific Image Office Equipment & Supplies Experts
 Grubhead
Grubhead
ADMIN Andrew
ADMIN Andrew
Are you a Pacific Image Office Equipment and Supply Expert? Answer questions, earn points and help others
