Smart Pulse Livescribe pen Logo
A
Anonymous Posted on Feb 21, 2014
Display very dim
My Pulse's display seems to be stuck at about 10 or 20% brightness. It's hardly visible. Reset doesn't work, neither does changing the settings. (it shows the setting change between 100 all the way to 10%, but nothing happens in brightness)..
JVC SR-DVM700U the front display is dimming quit low to where i cant read it
If the front display of your JVC SR-DVM700U is dimming to the point where it is difficult to read, there are a few potential causes and troubleshooting steps you can try:
1. Adjust the display brightness: Check if your device has a dedicated display brightness control. It could be a physical knob or a setting in the menu system. Increase the brightness setting to make the display more visible. Refer to the user manual for specific instructions on how to adjust the display brightness.
2. Check the power source: Ensure that the device is connected to a stable power source. If the power supply is fluctuating or inadequate, it can cause the display to dim. Try plugging the device into a different power outlet or using a different power cable to rule out any power-related issues.
3. Clean the display: Dust, dirt, or fingerprints on the display surface can also affect visibility. Gently clean the front display using a soft, lint-free cloth. Avoid using harsh chemicals or abrasive materials that could damage the display.
4. Check for backlight issues: The display might have a backlight that illuminates it. If the backlight is malfunctioning or failing, it can result in dimness. Unfortunately, in most cases, repairing or replacing the backlight requires professional assistance. Consider contacting a qualified technician or JVC customer support for further guidance and potential repairs.
5. Reset the device: Perform a factory reset on your JVC SR-DVM700U. This can help resolve any software-related issues that may be affecting the display. Consult the user manual or contact JVC customer support for instructions on how to perform a factory reset on your specific model.
If the above steps don't resolve the issue, it is recommended to reach out to JVC customer support or consult a professional technician who specializes in JVC audio/video equipment. They can provide further troubleshooting guidance or recommend appropriate repairs if necessary.
Camry 2008 XLE V6, Instrument panel lights are too dim in day light , works normal in night .
seems to me the lamps are dim in the cluster, as in bad lamps.
the dimmer works, but can be tested, if 12vdc out on high.
the dimmer is good.
car drives perfectly,day and night, heater blower on high works.
all things on car seem to work, but just dash dimmer?
why do you need lamps in the day, not told..??? I don't
my cars never glow dash lamps (background) lamps in day
the other IP c luster lamps are ERROR lamps.
like ,(lots) CEL, charger fail,
all my error lamps are out, driving, as they must be.
so only background lamps are dim?
are outside of car PARK lamps all working?
LCD screen is white, dim picture and sound works fine
seems the white balance is set inccorectly and the brightness is set wrong check your TV's menu and set them back to normal or reset the display controls in the tv menu if it turns all back white and dim then the display panel of your tv is needing repair
Dim screen acer 5100-3019
Try going into power option settings and taking the brightness to the max there. Start, control panel, power options, then you should see a setting for battery and for plugin. Hope this helps.
Buick Rendezvous Head Up Display
not sure about that one but there is a dimmer wheel by the light switch. move it up and down to dim and brighten the dask lights/cluster. wheel may need replacing. also work the lights on and off switch manually to see if there every thing works smooth or hopes from dim to brite.
204b backlight getting dim
change the inverter if it does not work ,you will have to change the backlight bulbs or you change the screen
1helpful
Display dim
Open the menu and change the brightness/contrast settings. If there is no change or if the picture seems dim, then it is a possible fault in the power section within the monitor or a fault in the display driver/convertor section.
I can't adjusts my laptop brightness..i tried everything..display settings nothing seems to work..only when is charging seems like the brightness is better..but when i remove the charger it doesn't look...
The setting you need to change there is your power settings. The laptop dims the the display to save power when its unplugged. You will have to go into change power options from diplay settings i think.
1helpful
HP dv1000 monitor just stopped working.
Description During the startup or boot process of the notebook, the display is very dim and barely readable. It remains dim when it reaches the Windows desktop. Restart the notebook with AC power Perform the following steps to determine if the dim display is due to a hardware failure:
  1. Connect the AC adapter to the notebook and a working electrical outlet.
  2. Power down the notebook PC by pressing and holding the Power button for 5 seconds.
  3. Press the Power button again to start the computer.
If the display is still dim after restarting with the AC adapter connected try changing the LCD brightness. Change the LCD brightness From the Windows desktop, hold the Fn key and press the F7 and F8 keys to increase or decrease the brightness of the display. If using the function keys does not resolve the problem, determine whether the Lid Actuator switch is stuck. NOTE: The key number may vary depending on the notebook PC. The image on the key should resemble the following images: Figure 1: Brightness Level Down c00776225.jpg Figure 2: Brightness Level Up c00776226.jpg NOTE: During battery power operation, the notebook display will dim to reserve battery power. Adjust brightness control using the control panel Some notebook PCs have the ability to adjust the brightness through video drivers. If the notebook PC has video drivers with this capability, perform the following steps:
  1. Click Start , Control Panel and then double click Display .
  2. Select the Settings tab and click Advanced .
  3. If the feature is available, a tab with the video card name will be present. If it is, select that tab.
  4. Adjust the desired brightness.
Finding the Lid Actuator switch The Lid Actuator switch is a small button or switch located above the keyboard and LEDs on the right or left side of the notebook. It may also be located near the display hinges. Pressing this switch when the computer is on may turn the notebook display off or cause the notebook to enter a different power state. Press the switch 2-3 times while observing the display. If the display is no longer dim the switch may need to be repaired. Contact HP service and support for further assistance. Contact HP service and support If the display remains dim after the troubleshooting in this document it may be possible that the backlight is damaged. Please Contact HP service and support to schedule a repair
Top Smart Computers & Internet Experts
vince
Paul Bade
Are you a Smart Computer and Internet Expert? Answer questions, earn points and help others
