Question about LG LHD659EBL Dehumidifier
Will not stay running - LG LHD659EBL Dehumidifier
I have a Frigidaire dehumidifer model FDL70S1 that wont stay running for more than 3 minutes and then it shuts the fan off, but still has power to the unit.
Hi lynn crisp, thanks for your post!
From my understanding you are having a challenging time with your Frigidaire dehumidifier shutting too quickly. It sounds like a possible problem with your sensor or control panel. Are you currently under warranty? I would contact your manufacturer for assistance to a proper resolution. -Matt
Oct 20, 2014 | Frigidaire Dehumidifiers
The full bucket light stays on yet no water is collected
if water full light stays on the compressor wont start and remove water from air , investigate why light stays on ? is bucket really full? is sensor knocked out of its fragile holder ? is bucket all the way inside machine so that sensor is connected ?
Jul 04, 2014 | Kenmore 54501 Dehumidifier
My zenith dehumidifier won,t stay running
if it runs for just a few seconds then clicks n stops its probably the thermistor in the motor starter circuit Re: Jeff
Apr 13, 2012 | Dehumidifiers
I cannot get this thing to stay on. The fan runs for about a minute then shuts off. I have tried unplugging it and plugging it back n and I have tried adjusting the percentage on the unit but it will not...
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
Apr 11, 2011 | GE ADER65LN Dehumidifier
Will not stay running nor will it pull moisture in the room.
There are many reasons why a dehumidifier will not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier
heatman101
Feb 21, 2011 | Soleus Dehumidifiers
Unit Changes Speed While Running
It may be slowing when the compressor starts, you may want to check the outlet it's plugged in to.
Jun 17, 2010 | Kenmore 53701 Dehumidifier
It starts with control set to max and it runs a couple of minutes and it stops so i turn the control to low and back to max it starts again and stops the same way the humidity is at 60+ so it should stay...
one of 3 possible problems,the control is faulty,you can bypass this with a jumper wire and see if it stays running, the condenser coil is dirty and is not cooling the compressor correctly and the condenser and evaporator coils need to be cleaned,i would do this first before bypassing the control,then possibly its low on refrigerant and the low pressure switch is shutting it down or the switch itself is faulty,please rate this if it helped you,thank you
May 30, 2010 | Goldstar DH304 Dehumidifier
It won't come on and when it does it won't stay running
There are many reasons for a dehumidifier tto not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier.
http://www.fixya.com/support/r4662409-dehumidifier_running_but_no_water_in
heatman101
Apr 03, 2010 | LG DH30 GoldStar Dehumidifier
LG LHD659EBL Dehumidifier Logo
60 people viewed this question
Top LG Dehumidifiers Experts
Bill Long
Gil Shultz
Anthony Ward
Anthony Ward
Are you a LG Dehumidifier Expert? Answer questions, earn points and help others
