When powering coach with an Onan 12.5KW Diesel Generator and the Xantrex RS3000 inverter is on, washer/dryer will not function correctly. The WD2100 power supply is turning on and off causing the unit to not operate correctly. If coach is on shore power, washer/dryer is functional with inverter on. If I turn the inverter off, WD2100 functions fine with generator power. I believe that the generator in conjunction with the inverter is inducing noise (3rd order harmonic) back into the AC line that powers the WD2100 and the power supply in the WD2100 can't deal with the noise. The AC leg that powers the WD2100 is also the same leg that powers the RS3000. This has been a problem since the coach was purchased new in March 07. Splendide sent me a new modified power supply board which didn't fix the problem.
Are you still under warranty with your RV? If so, take your RV back to them and try to get this problem fixed through them. You know more about electronics than I do (LOL) however, I do believe the RV sales/repair should be taking care of this issue for you.
I on the other hand own the Majestic brand washer and dryer and I am very dissapointed with them. The washer is broken already and is only 15 months old. Ugh!
Good luck, I hope your issue is a simple fix.
