Question about Samsung ES60 Digital Camera
Samsung es60 card locked solution
Possible to not taking photo.when i press fr taking photo ,displays shows card locked
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Samsung Master
  • 102,366 Answers
Look at your memory card. SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Posted on Feb 22, 2014
6ya staff
SOURCE:
Vic Fkiaras
  • 18 Answers
SOURCE: my camera says card locked
Check the side of your media device, it will be locke.
See pic: http://en.wikipedia.org/wiki/Image:SD_Cards.png
Slide the little switch to the unlock position.
Posted on Dec 09, 2008
robmcd27
Rob
  • 423 Answers
SOURCE: samsung digimax4010 memorycard locked cant take pictures
To fix this, remove the SD card from your camera. Look on the side and you will find a little switch. One end of the switch says locked the other end says unlocked. Move the switch from locked to unlocked. Replace it in your camera and turn it back on.
Thanks for coming to FixYa and fee free to rate my solution.
Rob
Posted on Feb 26, 2009
leecom72
Lee Hodgson
  • 4806 Answers
SOURCE: card locked!
Have checked that the write protect is off?
To remove the write protect lock, take the card out of the camera, face the card towards you, look for a small white tab on the left hand side of the card, to unlock it push the tab down, it will be at the side of the card like this 59a6de4.jpg .
Regards.
Posted on Aug 30, 2009
Ty Price
  • 11967 Answers
SOURCE: Card locked shows when attempting to take a photo.
Move the slide switch on the side of the card.
Posted on Sep 21, 2009
raslim
SOURCE: my SAMSUNG ES60 (digicam) lens
my samsung es60 dont open camera
Posted on Jul 18, 2011
How do i unlock 'card locked' ?
Mar 26, 2013 | Samsung ES60 Digital Camera
Look at the memory card. SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Can you give me the softwere ES60
You don't need any software.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or, despite what I said first, you can use any photo cataloging program such as Picasa.
Nov 12, 2012 | Samsung ES60 Digital Camera
CANNOT READ THE SD CARD
ALTERNATE WAY TO TRANSFER PHOTOS TO COMPUTER
If your photos are stored on the memory card, then remove the memory card from the camera and insert it into an USB memory card reader. Connect this USB memory card reader and memory card into the USB port of your working computer. Your computer will see this as an USB Mass Storage Device or an external storage device; you can then open the folder on the memory card and copy the photos to your computer. Memory card reader is a handy device and is inexpensive. You can copy photos from other cameras and you can also download photos off your memory card to someone else's computer without the need of installing any programs.
Aug 27, 2012 | Samsung ES60 Digital Camera
I have a samsung wb690 and i cant take any photos as card locked comes up
Feb 03, 2012 | Samsung Cameras
Memory card locked
There are several possible causes for "memory card locked", "memory card error", or "no memory card". The most common cause is having the tiny slide switch on the side of the card in the wrong position. The second most common is trying to use a 4GB or higher SDHC card with an older camera made before SDHC format came out. There are also other common causes if the above didn't help, with troubleshooting steps for this problem listed here.
Dec 11, 2011 | Panasonic Lumix DMC-TZ3 Digital Camera
When i try to take a picture it says 'card locked'??
Look at your memory card. SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Apr 01, 2011 | Samsung ES60 Digital Camera
Samsung ES10 8.1MP, card locked can't shot a picture
camera shows card locked when you insert memory card and can not take photos but without memory card it takes photos.even when you change memory cards it does the same.it says card locked.
Dec 25, 2010 | Cameras
Samsung digimax d53 is in standby mode cant take pictures
Try this...remove the card and battery...press all the buttons...leave it alone for 20 minutes...insert the card and then the battery...turn it on.
Jan 03, 2010 | Samsung Digimax D53 Digital Camera
Samsung ES60 Digital Camera Logo
Top Samsung Cameras Experts
FIKRET UNALIR
FIKRET UNALIR
Level 1 Expert
Anthony Ward
Anthony Ward
Are you a Samsung Camera Expert? Answer questions, earn points and help others
