New batteries do not fully charge or hold their charge first time. Use it, run it down, re-charge for 24 hrs and repeat. After 3d time should be okNew batteries do not fully charge or hold their charge first time. Use it, run it down, re-charge for 24 hrs and repeat. After 3d time should be ok
You can't post conmments that contain an email address.
hi,
it seems that you have changed the date of your tab in the Date and Time section. Thats why it is telling to you to wait for 970,000 minutes.Changing the date will fix this problem. Thanks
Try scanning for network but instead of logging in click arrow right and look for "forget network". this clears internal cache of any stored passwords that you may have recently changed.then scan again and it will ask for new password and this time remain logged in as you will have removed conflict.
What is the brand name of your tablet?samsung tablets are easy to disemble. For tab 1 & tab 2 remove the back cover of the tab...do it gently otherwise you could just break it...now just remove the battery pin which is connected to pcb...if you have booster then boost up the battery then put back in tab & try to switch on the tab if doesnt turn on insert charger into port then wait for 2-3mins
