Question about Marshall Amplification Marshall MS-2 Mini Amp
Sound fades. Clean channel has some overdrive in it at all volumes. After 10 minutes, sound starts fading, both clean and overdrive, and keeps doing so. I suppose it's an overheating thing. Any suggestions? And please don't say use fan, because in the MS-2 there's barely room for the existing components, as it is.
  • 93 Answers
Jumper the power amp in jack to the preamp out jack [or effects send jack to the effects return jack]. There may only be oxidation in the contacts of these jacks. If the normal sound level comes back-either clean the two jacks or have them replaced.
Posted on Nov 23, 2014
    Habit-Forming:
  • 56 Answers
Did you try a new 9 volt battery?
Posted on Jun 22, 2014
3 Suggested Answers
Fred Yearian
  • 5603 Answers
SOURCE: Marshall DSL 100 - volume fades away and gradually comes back on
IF this is a vacuum tube unit, these symptoms are that of a tube that the heater is intermittent, that is it cools off due to a break and then liights again.
Open the back and observe the heaters in the tubes. DO NOT be fooled by some that have TWO heaters in them. (use a mirror if necessary) A single one that comes and goes can cause the problem and the voiration can make it come and go. This behavior in a tube is NOT somthing readily spotted in a tube checker. The delay in fading and coming back would be the delay in warm up following a heater going out and cooling.
Posted on Feb 15, 2010
pastorchad
  • 3 Answers
SOURCE: Marshall MG250dfx's sound fades out
I have read that the problem is in the FX send/return jacks which oxidize if not used much. All you have to do, apparently, is ram a jack plug in and out a bunch of times. This breaks up the oxidation, and allows the amp to work properly again.
Posted on Jun 23, 2010
matt
  • 22 Answers
SOURCE: Hi, my name's John...i have
It sounds like you bought a defected amp. You should contact Marshall and tell them the problem. You should have some kind of warranty.
Posted on Apr 04, 2011
My Marshall AVT150H has low output.
How do the pots sound? any stactic on the volume pots ? may need replacing or cleaning them if so . I would also consider replacing the tube
Jan 29, 2013 | Music
My Fender Hot Rod deluxe makes a popping noise when switching back to the clean channel.
This is because your clean channel only runs through the pre-amp section, requiring an increased volume level to match that of the volume of the drive section which is overdriven by the pre-amp circuit. my suggestion is to use lower volume level on the clean channel of the amp. To get any volume boost you may need to match the two channels you could use a signal/volume booster or overdrive pedal between your guitar and amp input, switching it off and back on when you switch back and forth between channels.
Jul 15, 2012 | Fender Hot Rod Deluxe Guitar Combo...
I have a crate fxt 120. I 'll be playing in the #2 overdrive channel and it will automatically fail and go to a clean sound. Although it is not entirely clean. It sounds like 2 sounds combined. A loud...
A possible problem MIGHT be marginal switch contacts on the external foot controller cable. If you are not using the foot pedal, these contacts must maintain contact to keep the same channel selected.
Sep 15, 2010 | Crate Music
Faded out the sound and will not turn power up
Make sure the STANDBY switch is not pressed. It will fade sound out on the first 8 channels and keep it off.
Sep 07, 2010 | Yamaha Emx312s Stereo Powered Mixer...
Feb 26, 2010 | Marshall Amplification Marshall MG250DFX...
Feb 14, 2010 | Marshall Amplification Marshall MG250DFX...
Handmade guitar amp, when i plugin the guitar i start playing, but then signal gets lost, the sound dissapears, and then it appears again, and after minute or two it dissapears. i've tried to put full...
have you got valves fitted to the amp as they can cause fading if old >damaged >not fittted properly also check the speaker connects and try playing half volume the output should be steady.. you say its handmade if you made it pull out the amp board and check your soldering joints look to see fi there is any that need resoldering as they may be getting hot and causing a resistor to fade..
Aug 02, 2009 | Orange Crush 30R Reverb Guitar Amplifier
LOW VOLUME FROM RIGHT CHANNEL OF STEREO 1 SIDE OF SYSTEM
It seems like the speaker jack tip needs cleaning, or the contact has become bent away from the connector and needs to be re-aligned.  The Passport is a portable system, so after years of plugging and unplugging the speaker jacks may be worn.  Try using the "Stereo 2" connectors. You can also try cleaning the jack with electrical contact cleaner, and. a cotton swab.
Jan 07, 2009 | Fender Passport Deluxe 500watt Sound...
Marshall Amplification Marshall MS-2 Mini Amp Logo
144 people viewed this question
Top Marshall Amplification Music Experts
Michial Gueffroy
matt martin
matt martin
Are you a Marshall Amplification Music Expert? Answer questions, earn points and help others
