Fisher Paykel EcoSmart GWL15 Logo
William Shelt Posted on Feb 22, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Motor or bearing sounds bad, how do you replace it
Very loud during spin cycle almost sounds like it is sliping and grinding during the spin cycle.
Dan Apthorp
Level 3:
  • Fisher Master 2,824 Answers
  • Posted on Feb 22, 2014
Dan Apthorp
Fisher Master
Level 3:
Answers
2824
Questions
0
Helped
889723
Points
7391
You have to unscrew certain body areas to get into the motor area depending on the make and the first thing I would check is see if the belt is shot. A bad belt will make noises as well as cause slipping. If the belt is ok check the shafts and see if there is play like movement if you push up or down . If it's the motor you may have to replace or take it to a repair shop if you don't understand how to do it. It does take some work to change a bearing
Testimonial: "Thank you, somewhat helpful. I went to a local appliance shop (not one of those big guys) and they actually told me what to do. I tore most of it apart after my post. The hammer is a very useful tool! A bearing was shot, hard to believe such a little thing could make so much noise. Finally got the nut off the shaft with some soaking of a lubricant. Since I have it all tore apart, I'm going to scrub all the parts with degreasers and clean all the sludge off everything else. Pretty easy, just time consuming. Putting it back together tomorrow! ]"
Paul P
Level 2:
Filmmaker:
Uploaded 5 video answers.
Scholar:
  • Fisher Expert 80 Answers
  • Posted on Jul 05, 2014
Paul P
Fisher Expert
Level 2:
Filmmaker:
Scholar:
Answers
80
Questions
0
Helped
61412
Points
218
The bearings wear out fast if the main shaft seal is leaking. It is recommended to insert a new seal with the new 2 new bearings. Otherwise the bearings will fail again soon.
Motor or bearing sounds bad, how do you replace it - 44192629-fd49-4216-883c-5ef3846307a0.jpg
1 Related Answer
Anonymous
  • 14 Answers
  • Posted on Jan 14, 2008
SOURCE: Ecosmart loud during spin cycle
My majestic sounds exactly the same on the spin cycle and I wondered what the problem was. Is your unit still under warranty? If so, call the customer service line and get a repair started. I am a firm believer in warranty work on products I have purchased. WE pay hard earned cold cash on our consumer products and WE should be taken care of properly.
Good luck and please let us know what the solution was to your problem.
I have a top load fridgidaire washer model fwsc445rfs0. During the wash cycle it makes a high pitched scraping noise.... Struggles also while it winds down before rinse. Bearing maybe?
How To Fix A Washing Machine Making Noise During The ...
removeandreplace.com/.../washing-machine-making-noise-during-the-sp...
Jul 27, 2015 - Agitator directional cogs aka "agitator dogs" (top load washers) ... If you hear a rubbing sound or the drum spins uneven, then the ... A washer making a loud noise during spin cycle can also be caused ... The clutch in a washing machine connects the inner wash tub to the ..... May 8, 2015; High Water Bill?
Dishwasher Making Loud Grinding Noise During Wash Cycle
removeandreplace.com/.../dishwasher-making-loud-grinding-noise-durin...
Apr 11, 2014 - Dishwasher Making Loud Grinding Noise During Wash Cycle ... GE, Whirlpool, Frigidaire, KitchenAid, Maytag, Kenmore, and LG) this is a .... Our Amana dishwasher is making a loud, high-pitched squealing noise throughout the wash ....Out Of A Washing Machine - Top Load & Front Load September 30, ...
All comments on Loud dishwasher Frigidaire Gallery mode ...
https://www.youtube.com/all_comments?v=v-arYb20kOk
Washer makes rumbling noise during spin cycle
You have to take the whole drum out and IT IS YOUR BEARING(s). Order all four of them
If you need further help, reach me via phone at https://www.6ya.com/expert/steven_b77d19396bfe2249
Washer is a Samsung WWF337AAW-XAC. Just prior to the spin cycle we hear a rattling or grating noise and then it rattles throughout the spin cycle. It will sometimes rattle at the end of the rinse cycle but...
hi Rick.
Reasons a washer will make noise during spin mode:
1. Main tub bearing faulty
2. Main drive pulley
3. Motor coupling worn
4. Bad clutch
5. Worn out drive belt
6. Clogged or damaged drain pump
7. Transmission is worn out
8. Shock absorber (front loader washers)
9. Springs or dampening straps (top load washers)
10. Agitator directional cogs aka "agitator dogs" (top load washers
When the washer spins, it rides on a bearing that allows the tub to move freely with zero resistance. If this bearing is worn out, a loud noise will be heard when the washer spins. A good way to tell if your washer problem is the main tub bearing will be that the washer noise will get worse or louder as time goes on. This means the bearing is becoming more worn out and close to complete failure. The bearing in your washing machine is a circular metal object that has many small little metal balls inside. These small metal balls inside the bearing sit in a track and move when the washer is spinning. If the tub bearing begins to wear out, usually the small metal balls inside can fall out one by one causing the noise you hear. (If your washing machine is a front load washer, open the door and turn the drum by hand. If you hear a rubbing sound or the drum spins uneven, then the main tub bearing is most likely bad and needs replaced.)
Washing machine tub bearing
Washer has noise during spin cycle
The bearing may also be without lubrication. If the sound you hear is more of a squeaking noise than a grinding noise, it may mean the bearing needs to be lubricated with a mechanical grease. If the sound is more of a grinding noise, then this usually means the bearing is falling apart and will need to be replaced ASAP. If you suspect your washers main tub bearing is worn out, the repair process is one of the most difficult to perform yourself. A worn bearing can also damage the tub of the washer. This means the tub (inner or outer) may need to be replaced also.
A washer making a loud noise during spin cycle can also be caused by a faulty drive pulley. The pulley is what the belt (if applicable to your washer) rides on to spin your washers tub. The pulley can be made of plastic or metal. It could be simply worn out or just loose. To find out if the drive pulley is causing the noise, you will need to take the washer apart and inspect the pulley for signs of damage.
WASHER MOTOR PULLEY
The motor coupling could also be the cause of the loud noise. The motor coupling in your washer connects the washers transmission to the motor. It is made of plastic and built to break if the washer gets overloaded. This is so the motor and the transmission do not become damaged. The motor coupling is an easier repair and can be done by most people.
Washer Washing Machine Motor Drive Coupling Coupler
The clutch in a washing machine connects the inner wash tub to the transmission. The clutch lets the washer get to the proper spin RPM in a gradual way. If the clutch is worn it can make noise when the washer is spinning. A bad clutch needs to be removed and replaced to stop the noise.
Washing Machine Clutch
The belt in your washer can become worn and cause noise while spinning. If worn out, replace the belt. Replacing the drive belt on a washing machine is an easy task and can be ordered online for less.
Washing machine belt
The drain pump in your washer that drains the water out could be clogged or damaged. While in spin mode, your washer may drain out the water by using the drain pump. If the loud noise only happens at certain intervals during the spin cycle, it may be the drain pump. Usually this can be fixed by simply removing the drain pump and removing any debris that may be clogging it up causing the noise.
Drain Pump for Washing Machine
The next part of your washer that can be causing a loud noise is the transmission. If the transmission is bad, usually the cost to fix this outweighs the cost of a new washer.
If you have a front loading washing machine, they all have shock absorbers. The shock absorbers are used to center the tub movement while in the spin cycle. These shock absorbers are connected from the washer frame to the outer tub. If the shock absorbers in your front loader become weak the washer will make a loud banging sound during the spinning cycle.
Shock Absorber for washing machine
Top load washers usually have springs or dampening straps holding the tub centered. If a spring or strap falls off or becomes weak, a loud noise will be heard in spin mode. Simply replace the strap, spring, or springs to remedy this issue.
Washing machine suspension springs
Agitator directional cogs are used to operate the upper part of dual action agitators (Top load washers). They engage the cogs on the inner area of the agitator as it turns in one direction. They release when the agitator reverses its direction. This lets the top part of the agitator to ratchet in only one direction. The bottom part will agitate in both directions. The cogs are made of plastic and wear out with regular use. They will start slipping and make a grinding noise. Another way to be sure that this part is bad is if you notice the top portion of the agitator does not move in a smooth motion. Removing the top half of the agitator to see if the cogs are worn out.
9helpful
Loud noises during spin cycles
Hello, If the noise is a squealing or grinding sound, you are likely looking at a bad seal and bearing.
If the noise is a knocking sound, it's more likely a suspension or out of balance condition.
Thanks
1helpful
Grinding grumbling sound upon start up , continuing at a quieter sound during the cycle, loud and grumbly during shut down
Hi.
f you get a very loud noise coming from the machine, and this noiseislouder when it spins faster, then it is often because of a problemwith the drum bearing.
The drum bearing is bad, probably drum bearing spider had broken.
On a front load the drum bearing is located at the back of the drum.
To replace the part you take apart machine, undo the belt and depending on the model you may need to remove more parts.
You can find parts and diagrams for most models here.
1helpful
Washer started grinding during spin, now won't spin at all.
sounds like the motor spun a bearing. Usually this requires a motor replacement. when the bearing breaks down enough, the lube no longer keeps the bearing cool. Then the friction just mounts up and makes alot of noise. after the heat from forcing a broken bearing the motor then overheats and then fails. after letting it cool it might reset itself but only to pop again because the bearing just gets worse until it locks up and becomes heat welded.
so there. I'd say motor replacement since the bearings and motor are all one unit.
Sorry, i hope this helps with the diagnosis
Kenmore Washer 110.94818200 Spin Grinding Noice
the bearings are bad and yes they can be replaced but a service tech will have to do it. very big job
FRIGIDAIRE FRONT LOAD WASHER
sounds like a bad bearing to me
Top Fisher Washing Machines Experts
Paul Bade
NOEL
NOEL
Are you a Fisher Washing Machine Expert? Answer questions, earn points and help others
