Vizio VBR220 Blu-Ray Player Logo
ed scanlan Posted on Feb 22, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My vizio blu ray player will play discs that i burn but no store bought discs dvd or blu ray
No store bought discs will play, both dvd and blu ray quickly say no disc but ones i burn on my computer work fine.
Nanny
Level 3:
Genius:
  • Vizio Master 2,351 Answers
  • Posted on May 18, 2020
Nanny
Vizio Master
Level 3:
Genius:
Answers
2351
Questions
0
Helped
988577
Points
7262
If your DVD player is in trouble of "no disc", you could refer to this tutorial about "How to fix a DVD "No disc" error".
TV Magic
Level 1:
New Friend:
Greenhorn:
A rookie expert who has answered 20 questions on their first day.
  • Contributor 64 Answers
  • Posted on Mar 01, 2014
TV Magic
Contributor
Level 1:
New Friend:
Greenhorn:
Answers
64
Questions
0
Helped
13555
Points
86
Sounds like it may need a software update. Quite common for dvd players. ring or contact where you bought it from or manufacturer and ask for instructions and obtaining files to update your player
4 Related Answers
Anonymous
  • 84 Answers
  • Posted on Apr 11, 2011
SOURCE: A new "Tangled" movie disc not play in Blu-Ray
As newer bluray movies come out they are constantly tweeking the format. More then likely you need to update your bluray players firmware or software. There should be an option under the menu for the bluray player to update the unit of course this will require that you have it hooked into the internet via ethernet cable or wifi network.
Testimonial: "This site was extremely helpful. Received resonse very quickly."
mlapres
Mike LaPres
  • 757 Answers
  • Posted on Sep 04, 2011
SOURCE: my blu-ray player is only
First confirm that the firmware update that you used is in fact for that very model.
Then check the region code for the discs in question.
Try the update again.
Anonymous
  • 14553 Answers
  • Posted on May 29, 2012
SOURCE: no disc message from player
Blu Rays are more complicated from a information point of view--you most likely have either a dirty or bad (failing) optical pickup in the player--this always shows up first with blu rays.
  • 19187 Answers
  • Posted on Apr 12, 2013
SOURCE: vizio vbr220 wont play blu rays dvds
The blue laser diode is bad.
2answers
My Vizio Vbr 220 wont play Videos from my usb
MP4 or AVI files will definitely work but make sure your USB memory is formatted in FAT32.
4helpful
My dvd player plays dvd discs ok. but when i use dvd burned on my computer shows no disc.the same disc plays fine on my computer
Some DVD and Blu-Ray players will not play a burned disc until it has been finalized. Finalize the disc on your computer then see if it will play. (Finaalizing a disc means it can no longer be recorded to, by the way.)
Shows unkown disc when i put in a burned dvd-r but it will play a store boughten disc what disc format is compadible with yhis unit
This model DVD player can play the following disc formats:
DVD-Video (Region 1 or relevant region coded store-bought movies)
DVD-R (must be finalised on appropriate recording equipment for compatible playback)
CD-R (for jpeg/mp3 media files)
CD-RW (for audio such as mp3)
music CD (such as store-bought albums)
This player will NOT accept DVD-RW/+RW discs, or Blu-Ray.
I hope this helps you a tiny bit.
4answers
How do I play DVD on the BlueRay player?
According to the Vizio website, your VBR231 CAN play DVDs the same way a lot of Blu-Ray players can. The site blurb suggests the VBR231 is backwards compatible - which means your player should be able to play DVDs as well as Blu-Ray. Generally, most Blu-ray players can play DVDs if they are backwards compatible with them.
I do know Blu-Ray discs will NOT work in most standalone DVD decks.
MODEL NUMBER: VBR231
*Model Features:
* Full HD 1080p Video Playback
* Integrated Dual Band Wi-Fi - 802.11n
* 7.1 Digital Audio Output
* Backwards Compatible (see below)
*Compatibility:
* Plays Blu-ray and DVDs, Audio CDs, MP3s and Jpegs
* Multi-Channel 7.1 Audio Output via HDMI
* Playback and Enjoy Media via back USB Input (JPEGs and MP3s)
*Outputs:
* HDMI 1.3
* Component Video (YCrCB)
* Composite Video
* Stereo Audio
* Coaxial Audio
* Optical Digital Audio
I hope that helps somewhat.
5answers
Plays dvds fine but won't play blu ray
DVD players can't play Blu-Ray . You need a Blu-Ray player for that .
4answers
How to play region A blu ray discs on region c Blu ray player. i have bought this player in India but would like to play BD discs got for USA, and the player does not plays such disc.
The Player will not play the Blu-ray discs other than Region C.
This is because all the Blu-ray/DVD Players are designed such way that it will play only the discs that are manufactured and sold in the same country where the Player is manufactured.
You can play the discs that are "Region ALL".
However, you may try copying the content of the Region A/B Blu-ray discs to a Computer then create a video Blu-ray disc to check whether you can play them in the BDPS370.
2answers
Can I play Blu Ray discs on a DVD-224 player?
No. Blu Ray media requires a different device technology provided only by Blu Ray players. It will not play on a DVD player.
When I place a DVD disc in it shows (no disc or unkown disc). It will play the DVDs that I have recorded on it but not those I purchased. Ray
this item will not play store bought disks it is for recording and burning blank disks you need a normal dvd player
Top Vizio Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
