Try to make surround sound with my speakers do not know how to wire them together for it to come from the tv
For surround sound, you need an A/V receiver with 5.1 or 7.1 surround capability. Depending on what kind of receiver you have, the DVD player, satellite/cable box, etc hooks to the receiver, those signals go out to the TV, and the speakers hook to the receiver. The receiver decodes the signal from the cable/satellite box or DVD player and routes it to the appropriate speakers. If the TV program or DVD isn't HD or coded for surround sound, the best you can expect is 2.1 channel stereo sound. OR, you can hook everything (DVD, satellite/cable box) to the TV and run an optical cable from the Digital Output of the TV to the receiver, which is basically the same thing, just a different way to hook everything up. Hope this helps
SOURCE: SA - VA1
Hey you might find a solution on this audio and wiring blog: www.audioholicblog.com
Hopefully this helps! Good Luck!
Dannyboy!
SOURCE: how do I get surround sound from TV?
see if ur DVD player has a TV/Audio in....you have to set it up so u watch TV threw your DVD player (if you have one of of the Surround Sound in a box systems) if you have SS w/ a receiver then you'd have to run Audio out from your TV/Cable/Satellite to the receiver for it to work
SOURCE: panasonic av control receiver sa-he200
On any 5.1 system without 2 zone capabilities when you press speaker "B" the receiver uses the rear channel amplifiers to send signal to the remote speakers. As a result the receiver cannot output signal to both the rears and the remotes at the same time.
SOURCE: THE SEARCH FOR SONY SA-VA1 SPEAKER WIRES
HEY COWBOY, I ALSO JUST PURCHASED A SET OF THESE TODAY FROM A D.I. STORE IN SALT LAKE (JUST LIKE GOODWILL BUT MANY TIMES BETTER) I TOO NEEDED THE CABLES AND FOUND THEM ON EBAY. HERE IS THE ITEM DESCRIPTION MAKE SURE TO ENTER IT INTO THE SEARCH BOX EXACTLY LIKE I AM GIVING IT AND IT WILL TAKE YOU DIRECTLY TOO THE ITEM.HERE IT IS....Sony #177553111 SAVA SA-VA 1 27 29 55 57 59 SPKR CABLE IF YOU HAVE ANY PROBLEM PLEASE EMAIL ME. i also bought the cable it was i believe 24.95 and 7.95 shipping i think. i used to own this set and they are a very nice tower speaker and sound very good i was fortunate to get mine today for 15.00 minus the center and rears. later jim
SOURCE: i have a panasonic sa-ht75 surround sound system,
You have probably solved this problem now, but incase you havnt, we had the same problem, the wrong lead came with ours, you need to plug the red and white into the audio out, and this should solve the problem, hope this helps
