Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
Posted on Jun 10, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
New eye sensor not lighting up when installed
I have a Chamberlin 1/2 motor.The eye sensor was damage, I got a new sensor and cut the old wiring and attach the new sensors. I match up the color .I don't see any power.The old eye sensor had a green light and the other had a yellow light.The new eye sensor have green on both.After the new eye sensor was attached. The new eye sensor's green light does not come on.It seems I have no power to either ligts.I can still close and open the garage door.I just have to rig it. by touching both the wire in back of the garage motor.
Should the eye sensor light come on?How do they get power.Please help!
Anonymous
Level 3:
President:
  • Master 3,197 Answers
  • Posted on Jun 10, 2009
Anonymous
Master
Level 3:
President:
Answers
3197
Questions
Helped
1458691
Points
8183
Make sure the sensors are pointed at one another. Also one of them should say "sending unit" and the other is the "receiving unit". Did you buy them new and from a dealer?
2answers
1994 Ranger 4.0 starts, runs briefly & cuts off
1994 Ford Ranger Workshop Repair Service Manual PDF Download Don't worry I'm sure you will get the solution of your problem, just check the link I attached
Suzuki aerio brake light switch
old post.
what year.
easy fix for any mech.
1: fuse blown.
2: brake switch bad,
3: wires bad.
4: PO (previous crazy owner) hacked in trailer wiring, and now
its all shorted out or he cut the wires, and uses useless wire nuts.
that are all corroded now , and useless.
5: collision damage never corrected.
first try it with one new light on each side , only 1, not 2
lamps can short easy (over twisting)
$1 for 2 new lamps, try that too.
1helpful
3answers
How do I replace the power cord on an electrolux 8502A vacuum cleaner?
1 Unplug the vacuum and remove all accessories such as extensions and brushes. Open the vacuum's outer casing to get at the end of the power cord. Exactly how you will do this depends on the model of vacuum. Generally it simply involves the removal of two to three Phillips-head screws.
2 Follow the power cord to the two connections at the vacuum's motor. Unfasten any clips or holding bracket and disconnect the cord from the motor. Sometimes this can be accomplished by unscrewing two connection screws, other times the cord is soldered directly to the motor. If this is the case use wire cutters and cut the cord about 4 inches from the motor to give room for splicing on a new cord.
3 Insert the new power cord into the vacuum. Follow the exact same path as the old one. If there were any brackets or clips that held the old cord in place inside the vacuum or out use them on the new cord.
4 Tie a knot in the cord on the inside of the vacuum casing so that it will not accidentally be pulled out of the motor once it is in use.
5 Connect the new cord to the motor in the same fashion as the old one. With wire strippers take off about 1 inch of insulation from the new cord to expose the two wires. Either wrap them around the connection posts and re-screw, or twist the new cord wires around the 4-inch remnants of the old cord and seal all exposed wire and connections with electrical tape.
6 Replace the vacuum's casing in reverse order from how you removed it. Plug in the vacuum to test.
Sep 11, 2011 • Vacuums
1helpful
Door will not operate unless you hold down button
I am presuming the following: is it that the door will not operate unless you hold down the button to "close the door"? And the button you are pressing is the hardwired wall button or control inside the garage correct? And if you try to close the garage door with the remote the overhead lights flash off and on or the motor make a clicking sound (about 5 clicks?)
The problem is either an obstruction of the safety sensors at the bottom of the door or, one or both sensor eyes are out of alignment. If you look closely at both safety sensor eyes on the part that faces into the garage, you should see a glowing LED. One side will be an Amber color and the other Green. If one is lit (amber) but the other is not (green), that is an indication that the beam is not being received by the receiving eye (amber).
If there is no obvious obstruction (check for spider webs, dust, try cleaning the clear lenses facing each other, etc,) Try re-aligning the sensors. When they are properly aligned the Green LED will be lit. Now, check the motor for operation.
If you have difficulty getting the transmitter eye (green LED) to light, try closing the door at the wall button, then, pull the red emergency release handle to disengage the door.
Now, try operating the motor unit with the door disconnected while using the hand held transmitter. If the motor unit operates to the close position while the door is closed but not when opened, then that sounds like there is sufficient light entering the garage to "Wash" the transmitter beam out so the receiving eye does not get it.
Contact Chamberlain/Liftmaster for Sensor eye blinder shields that can be easily installed by you. (they just snap on) If neither LED is lit, make sure that the wire to the sensor(s) has not been cut off at the sensor itself. If that checks out, check the connection at the logic board. Make sure that both wires are securely connected.
If after checking all of that, and you do not have either of the LEDs on, then disconnect the safety sensor wires from the motor unit's logic board. Then take a 2" piece of bell wire and jump it across the two terminals for the safety sensors. If the unit operates normally when using the hand held transmitter, then the problem is likely: a) Bad safety sensors b) Broken wire to one or both sensors
To check if the safety sensors are good:
Remove both sensors from their mounting brackets. measure about 8" to 12" of wire from the back of the sensors and cut. You should have about 8 - 12 inches of wire on each. Now, separate and strip the insulation from each and then match the white striped wires and twist them together, and do the same with the solid non-striped wires. Take the sensors up to the motor head and connect the spliced wires to their respective positions on the logic board. Now, Point the two sensors directly at each other (its okay if the clear lens part are touching each other) Check if both LEDS are now lit. 1) If YES; then the sensors are good, the wire to them is broken somewhere; [FIX] replace the wires for both sides. 2) If NO: then the safety sensors need to be replaced. [FIX] Replace the sensors, contact Chamberlain / Liftmaster for replacement parts. You will need your garage door opener's model # which can be found under the light bulb or light fixture on the opposite side of the logic board. Having the model # speeds up the parts search for you.
I hope this helps you out. [I have been factory trained on residential and commercial garage door openers by Chamberlain / Liftmaster and have been providing installation and tech support on them for over five years. Prior to that I used to install and repair these units, and I've done that for nearly seven years.]
I have a Chamberlin GDO 1/2 hp. The white wheel on the sprocket assembly had the teeth worn down. I replaced it according to instructions. I reassembled the motor pieces and tried the opener. I have...
Someone else can join in, but I think when it only moves that little, it has to be the RPM sensor. It may be installed correctly but the electric eye that "sees" the vanes turn may be dirty. Clean that out. I'll try and add the picture, or try here:
http://tinyurl.com/gearfix
Just installed a new battery and I have no power,
hi...
1.As you changed the battery and the volts are fine the problem lies with the wires connecting the starting motor.there may some cut in the wire which prevents the power goin to the started motor.
2.please check the fuse for the starter motor which might have blownout.
3.there may be some junction box/relay through which the power goes to the starter motor. this might have burnt out or damaged so please chekc this also
4.check the terminals connecting the battery and the motor also,
if my answer was usefull to you please rate me
Chamberlin door will not close
THE PROBLEM IS IN THE SAFETY EYES
EITHER ALIGNMENT - WIRING OR A BAD EYE
HOPE THIS HELPS
1helpful
2answers
Motor moves 5 in" and reverses and light blinks 5 times
In the manual it says if you can hold the wall button down & door closes. You have a short in the wiring to the reciever eye. Try substituting some new bell wire in its place, or test the wires for continuity.
1helpful
2007 toyota tacoma pressure sensor
If your new rims do not have the transmitters installed, the light is not going to go out.
If the new rims do have the transmitters installed, and one is broken during the installation, the light will not go out. It is common for tire machines to damage the transmitters.
If the rims have the transmitters installed, and all the tires are at the proper inflation, I would check the spare tire pressure. It too is monitored.
Thnaks for choosing FixYa for assistance. Please feel free to comment back if you have any futher questions. Thanks.
Top Sears Building Materials Experts
hsapiens
Level 1 Expert
Are you a Sears Building Material Expert? Answer questions, earn points and help others
