SOURCE: external speakers for toshiba laptop problem
Check device manager and make sure the audio drivers are not disabled. If so enabled it. I am quite sure you have checked to see if its muted. If it is enabled and its not working, try updating the drivers or uninstalling and reinstalling latest driver audio driver OEM site.
**If you reinstall the same driver you might get the same error but its what a shot.**
SOURCE: blank black screen laptop on acer 5520-5012,
So connect your laptop to an external screen. Turn your laptop on. Press start key on your keyboard and then press "P" key on your keyboard. Remember you must press them simultaneously. A small window will popup. Choose Computer Only. Hope it helps I assumed that you are using windows 7 or vista Do not forget to rate your answer.
Hi Joshua Campanilla, I want to help you with your problem, but I need more information from you. Can you please add details in the comment box?
