Relic By Fossil Silver Dial Stainless Steel Mens Watch PR6117 Logo
H
Holly Conley Posted on Feb 23, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
What is the replacement battery for a Relic watch PR6117?
I cannot find a number on the current battery, which needs replaced. Which one should I use for Relic model PR6117?
Bestway
Level 3:
Master:
  • Master 966 Answers
  • Posted on Mar 03, 2014
Bestway
Master
Level 3:
Master:
Answers
966
Questions
13
Helped
188363
Points
2495
Number is there on battery- use magnifier.
5 Related Answers
Anonymous
  • 3 Answers
  • Posted on Mar 04, 2008
SOURCE: Remove link form Relic Wrist band
For my relic ZR15372, all I did was take a thin, hard object (a thumbtack in my case) and carefully pushed out the connecting bar from the link.
If you look at the inside of the band of your watch, you may notice that on some of the links (the ones nearest the clasp for me) there is a little arrow pointing at the side - if you look at the side of the links, there should be a little hole, big enough to push a thumbtack into. If you apply enough pressure (again, carefully - no need to stab your thumb or any other part of your body), the connector pin should slide out a little on the other side. Then it's just a matter of pulling the pin out - perhaps a pair of tweezers would do the trick.
Hope this works for you!
A
Anonymous
  • Posted on Sep 29, 2008
SOURCE: Need to replace band on Relic ZR50003/1200607 watch
Hi i need to change the band in my watch any idea how to do it ?
Many Thanks
Wiola
escapement
Arturs Kalnins
  • 2338 Answers
  • Posted on Feb 10, 2009
SOURCE: Mens Relic watch stopped working after battry change
I suggest that your watch has an oxidized contacts and electricity can not reach the movement.
Do as folloes:
Take out the batttery,
Clean (scrape) all battery related contacts till they are shiny (use hardened steel needle for that),
Use the dust blower to get rid off any tiny dust and dirt particles after cleaning,
Refit the battery back.
Now your watch should work again.
If all written above do not help, then there is a problem with your watch and you will need the help of the watchmaker.
Do not forget to rate, please.
Anonymous
  • 2501 Answers
  • Posted on Feb 02, 2010
SOURCE: Need battery number for Relic watch model
Take your watch to a good watch shop and they will be able to replace the battery for you.
gemineye61
Janelle Schoonover
  • 842 Answers
  • Posted on Aug 20, 2010
SOURCE: How do I take the
Locate a very small tab (or recessed area) on the edge of the back cover. This is the access point for removal. You can find this sometimes by running your fingernail around the back rim, as this tab or indentation can be hard to see.
  • 2Pull out the stem, which releases the back on some watches.
  • 3Get a small flathead screwdriver it needs to be a thin inflexible tip. Use a kitchen knife as a last resort. Wrap the hand you are holding the watch with in a towel or protect your hand in some manner so you don't injure yourself if the screwdriver/knife slips.
  • 4Very carefully slide the blade under the tiny metal protrusion on the back cover (or across the length of the recessed area, depending on which type of cover your watch has). Do not attempt to insert the point of the knife. Use the length of the blade.
  • 5Get under the tab or recessed area and gently but firmly turn the blade upward, popping the cover off.
  • 6When you replace the cover, make sure you line up the stem slot on the cover with the stem of the watch.
  • Ad
    2answers
    What size battery do a relic zr11787
    Take your Relic watch to a jeweler who will identify the type (not size) and may replace it.
    1helpful
    Battery size for relic watch pr6117
    Hi BATTERY for you're watch AG4 1.5 V or 377-377A-LR626-SR626SW. Cheers
    What is battery number for relic watch zr11811
    Just replaced the battery in my colleague's Relic ZR11811. The battery is a 371. Equivalents include AG6 and SR920.
    1helpful
    BATTERY REPLACEMENT FOR RELIC WET WATCH ZR11657????
    If you can, pop the back of the watch off, the battery will have 3 digits, and some letters, for example 375R, 325LRW, etc. the 3 digit number is the type of battery you need. If you cannot read the number, then typically, if you take out the battery, and you measure the width, and height of the battery, then find another battery with the same measurements, it will work, trust me.
    i hope i helped!
    2answers
    What kind of batery need for relic zr 15490? i don't know because i lose my old batery.
    mcdevito75 Here, Your in a spot, Looseing the old battery to your Mens Relic watch, you can look for a small watch repair shop in your area, they may have an idea of the battery number, but will most likely tell you they need the watch to know for sure. You can also try battery 364 or 371 but even I can"t be certain. You can also try online at Contact Relic Watches.com Reic should have a website. You may be left with only 1 choice, have the watch repair shop replace this battery for you, you"d have to buy and try a couple of different batteries and each battery in the store runs about $5.00 each, at the watch shop let the Jeweler figure out the battery number for your watch for 1 price. I think this is your cheapest and best option.
    Need battery number for Relic watch model ZR15477--old battery was lost.
    Top Relic Watches Experts
    NOEL
    NOEL
    ADMIN Andrew
    ADMIN Andrew
    deton8 von Splosion
    Are you a Relic Watch Expert? Answer questions, earn points and help others
