Question about Uniden Bearcat Pro PC68XL 40-Channels Base CB Radio
Poor reception Can hardly hear
    Problem Solver:
  • 18 Answers
There are many causes for poor reception on a cb radio one cause may be poor or poorly assembled antenna, a good antenna should be of highest gain and put up as high as possible ,An omnidirectional antenna or Ground plane will hear moderately well
in all directions but a directional antenna or Yagi will hear great only in the direction it is turned you will certainly have to decide what you or your homeowners association will allow.
Also and finally The sun is a major factor in communications Propagation sometimes no mater what your setup the reception is terrible.
Posted on Jul 12, 2014
Antenna removal
Poor reception is ant. No reception is radio. Poor explanation gets poor answer
Mar 12, 2014 | 1991 Chevrolet C1500
Poor radio reception
check your antenna wire to see if it came unplugged from back of radio
May 18, 2013 | 2002 Ford Crown Victoria
Poor radio reception and Setina push bar installation question
for the poor reception have you plugged in the antenna wire into the radio
Poor reception when trying to get MW
Poor reception or with heavy noise aas the interference is very high on the MW. If there is no signal strength then the fault can be due to faulty RF in the radio, poor MW oscillator settings or a faulty IF settings.
Also a faulty antennae can cause poor reception and pick of stray signals.
Check for other interferances from household applicances.
Nov 07, 2011 | Car Audio & Video
I have an '02 Kia Sedona. Rasio has been working great for all these years but now various stations have very poor reception. We have checked the antenna and it is secure and looks fine. Any ideas?
Did u set ur radio to "LOCAL"?
If u did, reception will be poor, undo the "local" setting for normal reception!
Hope that might help u out!
Nov 18, 2010 | 2002 Kia Sedona
Turn up volume to talk cannot hear what people are saying to me!
if in case you happen to cover the antenna area of your phone while speaking, it will affect the incoming signal reception and that in turn may cause poor volume
Jun 30, 2010 | Nokia 2680 Slide Cell Phone
Some channel no sound
Hello Blwas5 hi, If some channels have sound and others none, its either the TV has poor reception or, its the channel's weak signal. check them both or see if your neighbors TV acts like yours. If thy neighbor reception is good, then thy TV has poor reception, you can't do anything to fix that. get another TV with good reception qualities.
Jun 18, 2010 | Sanyo Televison & Video
!994 Park Avenue FM radio reception poor. AM signal OK
Check antenna connections at radio and antenna assy.. Poor connections will only receive AM and hardly any FM
Apr 06, 2009 | 1994 Buick LeSabre
Poor reception
Go to a radio shark or to a phone store and tell them u want the Reception Booster that goes inside ur battery pack and this should improve ur Signal. :)
Feb 10, 2008 | Motorola Mobility RAZR V3
Uniden Bearcat Pro PC68XL 40-Channels Base CB Radio Logo
107 people viewed this question
Top Uniden Radio Communications Experts
Jason
Robert McClure
Marvin
Marvin
Are you an Uniden Radio Communication Expert? Answer questions, earn points and help others
