Big Button TV Universal Remote Logo
A
Anonymous Posted on Feb 24, 2014
I need a code for my prizma tv - Big Button TV Universal Remote
3answers
Need code for GPX TV need code for GPX TV need code for GPX TV need code for GPX TV
Why ask the same question 4 times, once would be significant. Contact the manufacture or if you're using a universal remote find the codes online.
Need a remote code for a cinemavision tv
v code universal remote cinemavision Questions & Answers ...
www.fixya.com > Forum > Tags
TV...need code for the GE Universal TV Remote. Thanks i have a 19 inch symphonictv and lost the codes for the ge rm25001 universal remote I have a GE ...
Need manual and code for cinema vision tv - Fixya
www.fixya.com/.../t10271608-need_manual_code_cinema_vision_tv
Aug 29, 2011 - need manual and code for cinema vision tv - One For All URC-3021Remote Control question.
what are the tv codes for panasonic tv's? ' Yahoo Answers
https://answers.yahoo.com/question/index?qid...
Mar 14, 2009 - i have anew universal remote and i'm tring to make it work wiyh my tv. tva ... Best Answer: Here are the available codes for a PANASONIC TV: 0007 ... WHAT ARE THE REMOTE CODE FOR PANASONIC CINEMAVISION TV'S.
My turning signal dont work on my geo prizma what fuse do i change
Turn signals have both fuses and relays. Inside your fuse panel... remember most cars have two fuse panels. One is under the hood and the other is under the driver's side footwell of the dashboard. Read the inside cover of the fuse panel box and it will tell you exactly which fuse and relay go to the turn signals. Look at the diagram carefully and count the fuses and relays to pull out the proper ones. You can easily see if the fuse is burned out when he wire connecting the two sides is burned through. A relay is difficult to check, just buy a new one and pop it in the correct spot.
9helpful
4answers
QUIERO SABER CUAL ES EL CODIGO PARA UNA TELEVISION SHARP SP
aver si te ayuda esto
Code 000 for RCA TV Code 003 for RCA TV Code 004 for RCA TV Code 005 for RCA TV Code 006 for RCA TV Code 007 for RCA TV Code 019 for RCA TV Code 054 for RCA TV Code 055 for RCA TV Code 082 for RCA TV Code 096 for RCA TV Code 098 for RCA TV Code 099 for RCA TV Code 100 for RCA TV Code 101 for RCA TV Code 102 for RCA TV Code 103 for RCA TV Code 129 for RCA TV Code 179 for RCA TV Code 181 for RCA TV Code 188 for RCA TV Code 190 for RCA TV Code 196 for RCA TV Code 202 for RCA TV Code 203 for RCA TV Code 212 for RCA TV Code 215 for RCA TV Code 233 for RCA TV Code 281 for RCA TV Code 352 for RCA TV
estos son los codigos
1helpful
3answers
I have a RCA Universal RCU430-needcode for Magnavox TV
Code 000 for Magnavox TV Code 004 for Magnavox TV Code 006 for Magnavox TV Code 008 for Magnavox TV Code 019 for Magnavox TV Code 062 for Magnavox TV Code 068 for Magnavox TV Code 069 for Magnavox TV Code 075 for Magnavox TV Code 076 for Magnavox TV Code 077 for Magnavox TV Code 088 for Magnavox TV Code 130 for Magnavox TV Code 132 for Magnavox TV Code 133 for Magnavox TV Code 134 for Magnavox TV Code 183 for Magnavox TV Code 219 for Magnavox TV Code 235 for Magnavox TV
3helpful
2answers
"I need to program an old Panasonic TV with a RCA universal remote model RCR311St Help""I need to program an old Panasonic TV with a RCA universal remote model RCR311St Help"
Code For Model RCR311S Code 1003 for Panasonic TV Code 1054 for Panasonic TV Code 1062 for Panasonic TV Code 1109 for Panasonic TV Code 1170 for Panasonic TV Code 1248 for Panasonic TV GOOD LUCK THESE ARE THE CODES LISTED FOR YOUR REMOTE/
1helpful
I have a rca remote (rcu404) my tv is a magnavox. I can not find my book so I need help finding the correct code to program the remote to the tv. Thanks I do not have the code book for my remote control....
8helpful
7answers
Need codes please for Jensen JER 422 for Magnabox TV
magnavox tv jer 422 codes are: 1000 1004 1006 1008 1019 1062 1068 1069 1075 1076 1133 1219
Top Big Button Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
Are you a Big Button Televison and Video Expert? Answer questions, earn points and help others
