Question about Brother CS-6000
Thread Take Up Lever Issue
My problem seems to be that after I have sewn for a few minutes sometimes slowing down and then speeding up but always on the 2nd sewing speed my thread will wrap around the thread take up lever. This causes my tension to loosen on the bottom of my seam. I have read and followed the instructions for threading the machine however this problem continues. Any suggestions?
  • Brother Master
  • 7,365 Answers
I've had that problem before, you can use a piece of tape to cover the take up lever or use a pair of wire pliers to close the take up lever just a little bit, so the thread will not come out.
Posted on Feb 25, 2014
  • Jill Reese
    Jill Reese Feb 25, 2014
    Thank you. I was thinking that I should try to close off the hook after threading. I will definitely give it a try. And thank you for not suggesting I wasn't threading it correctly. Arghhh lol
3 Suggested Answers
Mary Dunn
  • 1788 Answers
SOURCE: Thread wrapping around take up lever
I think that you should check the manual again because it sounds like you have missed a step in your threading. What you are describing does not seem possible if it threaded right
Posted on Jul 26, 2010
Mary Dunn
  • 1788 Answers
SOURCE: My brother LS-1520 sewing machine is having major tension problem
Try some metal bobbins, #15 or SA 156. that seems to help. If, you don't have a manual go to brother.com and download one for free
Posted on Jul 27, 2010
Tally Girl
Tally Girl
  • 1134 Answers
SOURCE: brother XL3500 thread keeps wrapping
Revisit your threading up, check the threading up path in your manual. The thread is missing a thread loop/guide I would say for the thread to keep coming loose and getting caught around the take up lever. Is it fully into tension? Always raise the pressure foot when threading up the top of the machine to ensure the tension is wide open so the thread seats properly.
Posted on Jun 16, 2011
My name is Darcy from Sask. Canada. I am an independant self employed person who does repairs to sewing machines here.  Currently working on a Viking/Husqvarna #1 computerized sewing machjne and am...
a foot controller is a simple speed controller
Any generic make that has the same specifications will do the job
Have you done a proper continuity check on the lead as it indicates broken wires in the cord
Oct 07, 2018 | Sewing Machines
Tension issues on my singer quantum 9960
A #16 needle seems pretty big for FMQ. Are you also getting pin holes in the fabric? Try using a top stitch, embroidery, or metallix needle.
Eyelashing is often a result of moving the fabric too quickly. Try speeding up your sewing speed or slow down the fabric movement. The object is to get the stitch speed equal to the fabric movement--and keeping it consistent. I tend to make swirls too fast which causes eyelashing.
It could also be tension. Be sure to ALWAYS RAISE the presser foot when threading the top thread.
What causes thread eyelashes when sewing
LOOPS Tension or Speed
Dec 10, 2017 | Sewing Machines
Speed control
I haven't sewn on this model in about 10 years, so I am rusty. I don't recall a slide or switch to set the range of stitch speeds, so one of the things you need to do is learn to feather the pedal instead of just stomping it. You can often figure out how to block the pedal travel with a couple thicknesses of cardboard cut to shape, or a piece of pencil eraser to mechanically block the highest pedal pressure, but usually it's just better to learn to control the pedal. Finally, the best free motion quilting is often done with high speed stitching but moderately slow fabric movement.
Feb 14, 2014 | Juki TL-98Q
Sewing machine slows to a stop.
When was the last time you oiled it?
Sewing machines need regular oiling as you use them - it sounds like you have or are close to seizing the bearings.
In future, when you smell burning and a machine that should operate at full speed slows down - stop, don't persist in using it.
It clearly has something wrong with it.
Your users manual should cover oiling the machine - there are predetermined points at which you drop the sewing machine or 3-in-1 oil into. Only a few drops are necessary, but you should oil it every few hours of use.
Jan 11, 2014 | Omega 6147 Sewing Machine
Goes too fast, has no slow speed, sews several stitches at a time and I am unable to stop when I need to
Sometimes the foot pedal sticks, tap on it a few times with your foot to get it to stop, if that doesn't work, unplug the machine for a few minutes then try, if that doesn't work then it will need to go in for repair.
Aug 06, 2010 | Sewing Machines
Singer 258
There is no speed adjust, but 1st you must know the source of the slow down. Remove the belt from the motor pulley and run it, if it goes fast try turning the hand wheel if it is stiff the machine needs clean and oil. If it turns freely you motor may be dirty or just slow. If dirty, sometimes you can without the blet attached run it at full speed for 10 to 15 minutes. It should get faster as you run it. If not motor is weak or slow needs replace. Just replacement motor as genuine probably no longer available.
Jan 15, 2010 | Euro-Pro 9105 Computerized Sewing Machine
Machine does not sew steady or fast...have to pump foot pedal
Machine is slowing down if it has to change the speed. So if design contains a lot of long stitches or not optimized it will be sewn slow. If your software is surely updated to the latest version and still machine is sewing slow then probably you need to optimize your design.
P.S. Software Live Update you can find under "Help" submenu.
Nov 21, 2009 | Singer CE-200 Quantum Futura Computerized...
Free motion quilting skipped stitches, breaking threads
Might be that you need to lower the tensions quite a bit, you'll have to juggle with top and bottom tensions though, and experiment for just this operation with the Sensormatic.
Mar 27, 2017 | PfaFF Sewing Machines
Brother CS-6000 Logo
333 people viewed this question
Top Brother Sewing Machines Experts
Irene Tulloch
Douglas Plant
Douglas Plant
PHYLLIS SMITH
Level 1 Expert
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
