Question about Durabrand DWT1905 TV
Cant change input with out a remote
When I go to the menu on the tv I can not change the input
Cant use menu
You may need a different remote. Is this a universal remote? Some of them have these common problems. Mine, for instance, doesn't use the OK button at all; instead, the Menu button counts as the OK button.
Try navigating the menu with the TV's volume / channel buttons (the ones on the TV itself, not on the remote). This usually works. Try that until you get a different remote.
Jan 29, 2018 | Vizio VX32LHDTV10A 32 in. LCD HDTV
My tv will freeze on menu
Looks like there is/are jammed button/s in the remote. Try removing the batteries from the remote and using control panel of the TV.
Jul 28, 2012 | Vizio M470NV 47 in. LCD HDTV
I cant figure out how to put the tv on video 1
With the remote in TV mode, the input button on the remote should change the source (TV, AV1, etc. depending on the TV).
If the input button doesn't work, try a different code for your TV manufacturer. A code that controls the basic functions of the remote may not control the full set of functions of the TV. For some TVs, you can change the source from within the Menu. (It depends on the TV. I didn't notice if there was a Menu button that will open the TV menu on the RCA RCU600M.)
If none of the codes work, check if your TV has a Source or Input button on the unit. See if that button works.
If you have a different remote, please indicate the model.
I hope this helps.
Oct 13, 2011 | RCA RCU600M Remote Control
Toshiba 27A41 27" TV Remote is lost. Need to change the input. Can I do this using the buttons on the TV? Can I program my DirectTV remote to change the input?
You can't chage it with your Direct TV remote control. If there is menu button in front of the tv, just go through the menu, and see the vedio options. From there you can change the input selection. If there is no menu button, you can't do anything without the help of remote control handset.
Oct 15, 2010 | Toshiba 27A41 27" TV
Menu keeps flashing remote control wont work, cant change channel or volume.when i hold down channel up andmess with remote sometimes it changes channel. channel down button is only one that doesnt change...
U have 2 situations:
1st U have a tv Key stucked or internal control board defective.
2nd U have a broken tv remote control.
Note: Check for stuck pressed keys on TV, if not send to repair shop, for checkup.
Nov 29, 2009 | Insignia IS-LCDTV32 32 in. Television
I have no remote and can't change inputs
well most tvs come with a game in put that you can change on your tv menu but if you cant you will need a universal remote
Oct 25, 2009 | iLO IWT3206 TV
Lost remote were to get code for 1988 colortrack
cant get input to work to play dvd menu wont come up with universal remote
Dec 23, 2008 | RCA 27V520T 27" TV
Sanyo DS24205 24" TV input problems
I'm sure you know you need the original remote if there is no menu on the front of the set. I suggest doing a search for customer support online for Sanyo products. There you will find contact numbers to see if one is available. Try "Sanyo remotes" on Google or Yahoo etc. Hope this helps
Dec 30, 2007 | Sanyo DS24205 24" TV
Whana change my sanyo tv to input to play games?
you need a sanyo remote with input button - can buy from www.sanyo.com
Dec 09, 2007 | Sanyo DS31590 31" TV
Durabrand DWT1905 TV Logo
110 people viewed this question
Top Durabrand Televison & Video Experts
matt martin
matt martin
Are you a Durabrand Televison and Video Expert? Answer questions, earn points and help others
