I do not have access to specific circuit diagrams for the ESP2 Singer Steam Press. However, I can provide some general information that may be helpful.
The ESP2 Singer Steam Press operates by using an electric heating element to heat a water reservoir, which produces steam to press clothes and fabrics. The electrical circuitry of the steam press includes a power switch, heating element, thermostat, thermal fuse, and indicator lights.
The power switch controls the flow of electricity to the steam press, allowing the user to turn it on and off. The heating element heats up the water in the reservoir, producing steam that is released through a pressing plate. The thermostat controls the temperature of the heating element, ensuring that the water is heated to the desired temperature. The thermal fuse acts as a safety device, preventing the steam press from overheating and potentially causing a fire. Finally, the indicator lights inform the user of the steam press's current operating status, such as whether it is heating up or ready to use.
If you're experiencing issues with your ESP2 Singer Steam Press, it's recommended that you consult the user manual or contact a qualified technician for assistance. Modifying or repairing electrical equipment without proper knowledge or training can be dangerous and may cause injury or damage to the equipment.
It turned on, all lights working and i can hear it heating up and when opening the calcium deposit i can see steam.
When i pressed the button - nothing. The iron it's self is hot (the plate) the lights on and but no steam.
The cord connecting the iron to the steam was also cold, so i could tell no steam was getting to the iron at all.
I wasn't sure if it was the button not working or something clogging the cord to the iron.
I did the vinegar thing. Let it sit for sometime (40 mins) and still nothing.
I did a weird thing of very carefully putting water on the plate while hot and it created steam from the plate. i think some backflowed and it started steaming, within seconds. might have happened with a bit more time anyway, but it def helped. All wokring fine now :)
please see the cause and fix it: a) tank or ports clogged. Dissasembly and inspect replace tank and seal if badly clogged. Emptying iron after each use allow heats to evaporate remaining water and helps prevent clooging. Inspect valve and linkage: clean or replace as necessary GOD BLESS YOU
i know mine won't steam either unless you have the dial set to steam. not sure if your has the same set up but i thought it might help to offer the information
Check the water reservoir for clogg. Be sure that the cleaner has water on it and it is heating. .If not heating there you'll sure it won't give steam. Check the heating element for open or no continuity. Heated water needed to generate or produce steam and you'll need a continuity tester to test it. Replace it with similar model and rating also with same size. Good luck.
This has worked for my SX8040D, but may not be a permanent solution. Fill the reservoir with clean tapwater - not demineralised or softened and not bottled water. Turn on iron and wait 20 minutes. Then try.
If you need instructions go to www.HandBookLive.com. There are videos for GS4 and GS10 under Appliances category. It says that steam is produced in about 5-6 minutes after you turn power on. Also there is a low water indicator light on GS10 that kills power to teh unit if the water level is low. Maybe that's the problem... Not sure if sc20 is similar
