battery/ charger malfunction has you battery been getting noticeably hot recently or remove battery and check its not swollen or even slightly misshapened if so discard for a new one if theres is none of these replace battery and try again if problem continues fit new battery and try new charger my monies on battery faulty
HI KUMAR SILU you can take the battery out of the phone look at the battery and see if the battery feels swollen or bloated in anyway . If it is swollen you will get a full chargwe in five mintues. Also the back cover will not fit on properly. tAKE THE PHONE TO YOUR NEAREST CARRIER IF IT IS UNDER ONE YEAR BECAUSE IT IS STILL COVER UNDER ONE YEAR man warranty, A word of advise is don't wait to long, Hope this helps
if they refuse to play any games the game slots will be damaged - often by using flashcarts (DSTTi R4I etc) they need new game slots fitting
if youre in the UK or EU see www.dsdoctor.co.uk
If you battery pack is swollen, then the worst thing to do is keep it in there and let it turn off and back on -- this could cause permanent damage to the device and could harm you as well.
Try and find a new battery on Ebay, CellPhoneShop.net, etc. and see if the problem is the battery or not. If it is, then that is the simple solution.
If the new battery doesn't fix it, then the situation is a little more sticky. Since the Audiovox 8910 is a fairly old phone, it is unlikely that you have any warranty left on the phone (unless you have insurance or have purchased it through Virgin Mobile, which in that case, go ahead and file the insurance claim or call VM and ask for a replacement or buy a refurbished one).
Most likely you will come out cheaper just buying a new phone altogether or finding a nice used one on Ebay.
Its appealing simple; Probably you will be accepting sony handcam charger accepting a cable thats declared to fit into ur camcorder and again allegation the battery. For charging the EFORCE FH50 battery, you just allegation to admit that the of the aforementioned cable anon into the battery(DC-IN slot) and bung ur charger into the bank socket. It commonly takes 135 mins to absolutely allegation the battery. Once answerable the LED at tthe DC-IN aperture will about-face off. (During charging its yellow)
If you got a USB cable with the unit, you can connect to your PC and recharge the battery that way. Just be sure to have the power switch turned ON. The screen on the player will indicate its connected and you should see the battery indicator in the lower right corner showing a charging condition (bar moving)
You will have to open your system case & install NIC into one of the PCI slots.Preferrably closest to CPU.
Caution: Turn computer Off & disconnect from power.
Once installed,boot computer & Operating System should find New Hardware & install.If not you will have to get drivers for the NCI
