Good Afternoon Rose, I am happy to assist you!
Before replacing the light bulb in your Frigidaire freezer please confirm that the temperature control is set in the OFF position and unplug your appliance to avoid electrical shock. Typically, you may remove the light bulb by turning it counter-clockwise. The old bulb can be replaced by an equivalent watt bulb (part number is 216988100) available either from part distributors or hardware stores. I hope this information helps to some degree!
Hey friend, thanks for your post!
From my understanding you have recently moved your Frigidaire freezer and it is now displaying the "OF". Normally, that stands for off you should be able to press the "Up" or "Down" arrow three times within five seconds to start your compressor. If you still need a copy of your manual could you provide me with your model number? You can locate your serial tag (which lists your model number) on the inside wall of your freezer. I hope this has been helpful. -Matt
