You are screwed, unless you know the security code, so take out any memory cards and do a factory reset. You will loose any data but he phone will work again.
This may be unrelated, but if you let the tablet go to sleep it will drain the battery. I found this out with my Stealth Pro about three months ago, I imagine it is more of an Android issue. It would not startup or go past the opening logo until I had charged it enough. This may also be the case if the battery is damaged or will not take a charge, in theory.
I had intermittent trouble with connecting my Trio Stealth Pro 7" tablet to my secure wireless. I have since upgraded my DSL modem / Bridge and have not had an issue since. You should contact your service provider if you have had the same equipment for a number of years.
You can try to go online on a different computer download compatible driver save to sd card then reboot your tablet . Id try a hard reboot first too see if that works
I HAVE AN TRIO STELTH PRO.I AM ON RR INTERNET.I CANNOT CONNECT TO INTERNET NOR WI-FI AT HOME BUT I CAN TAKE IT TO MY DAUGHTERS & IT WORKS FINE.ALSO MY LAO TOP WORKS OK ON MY WI-FI.IT IS BLOWING MY MIND.THANKS TROY PRUITT
