I have an older Maytag Neptune gas dryer; MGD4000. When the drum is spinning it makes a loud noise as if the drum is not secure. The inside back of the drum looks like its missing something, there's a large gap between the drum and back wall. There's a black rubber type scuff mark in the shape of a half moon on the back wall. Is this where some type of part may have spun out of the drum???
Thanks for your input, Mike 03885
SOURCE: Maytag Neptune Dryer Model # MDE3000AYW
Motor malfunctions usually call for service by a professional. There are three main causes of motor failure: lack of lubrication, a defective motor switch, or worn or frozen bearings. A humming sound can be related to a burned-out motor or a defective switch. Check these trouble spots before you call a professional service person or take the motor to a repair shop. Here's how to check a dryer motor:
Step 1: Remove the back access panel. Then reach behind the drum, motor pulley, and idler arm pulley. If these areas are clogged with dirt and lint, undue strain on the motor may be causing the humming noise. Worn or broken belts can also cause a humming noise. Check the belts for wear and damage. If the belts look all right, you may be able to stop the noise by spraying them with fan belt dressing, available at automotive and hardware stores and home centers.
Step 2: Turn the dryer on. The noise you hear may be the whirl of the spinning drum, not the motor. Some noise is normal.
Step 3: Force a little 20-weight nondetergent motor oil (not all-purpose oil) around the ends of the motor shaft. This lubrication may stop the humming noise. If this doesn't solve the problem, remove the motor and take it to a professional service person.The centrifugal switch on the dryer motor may be located on top of the motor. Humming, no motor power, and no heat can be caused by a faulty centrifugal switch. If the switch is externally mounted, check the terminals of the switch to make sure they are tight and not burned. If you spot trouble, remove the switch and take it to a professional service person for testing. A faulty switch will probably have to be replaced. Some centrifugal switches are located inside the motor housing; you won't be able to remove the switch in this case. Remove the entire motor and take it to a professional for repairs.
If the motor hums, but won't run the pulley on the end of the motor shaft, try turning the pulley by hand.Caution: Before turning the pulley, make sure the power to the dryer is turned off.
SOURCE: Maytag Neptune Dryer making vibrating noise while working
a bearing in the back for your drum sounds like what you describe. It needs to be taken apart and the bearing lubricated with high temp grease
SOURCE: Maytag Neptune Dryer smells like burning rubber or plastic...
could be the board, could be a motor, could be a belt but i would run it intill something just stops or try your best to take it apart and look through things and see if you can see an indication.
SOURCE: MayTag Neptune MDE6800AYW dryer drum making
Have someone change the bearing, it sounds like it has busted on ya. The rumbling sounds like the ball bearings in the bearing have failed.
