Usually because you didn't shut windows down properly before turning your computer off or completely draining your battery. If that is the case then simply select start windows normally and as long as you follow the correct shut down procedure it shouldn't happen again. If it does there may be a problem with your windows instalation.
Hey there, when your computer completely freezes while still being on you simply have to remove the power cable and pull out the battery. Then put the battery and/or power cable back in.
When you start up your computer again it will say your computer wasn't shut down properly, simply select "start windows normally" and everything should be fine again.
Try this unplug plug the power cord and remove the battery and hold the power button for 45 seconds,Then reinstall the battery and and try to start the computer,
if it fails to start unplug plug the power cord and remove the battery and hold the power button for 45 seconds and remove the memory and any usb devices that may be plugged in,then start it,
If it starts
Allow it to load completely and then shut it down and install one memory stick and restart, if all is well after if loads completely, shut down again and install the other memory stick and restart, if all is well again wait until it loads completely and then plug in and allow to load each of the usb devices you may have
Try to unplug the power cable then flip the laptop over on its closed lid and on the back should be an access to the battery. Remove the battery for about 2 minutes replace the battery and power cable. It should reboot to a black white screen giving 3 choices. You'll have about 35 seconds before the computer auto selects safe mode. Go ahead enter safe mode after it completely boots in safe mode shut down computer completely, wait 30 seconds and hopefully it will start up normally. If it doesn't you may have an issue with the operating system which unless your computer savvy and have all of the computers original cds you'll need to take it to a reputable computer repair shop
Don't know why the screen is blank. Toggle the F9 key to make sure you didn't accidentally toogle off the screen.
As far as turning off the power and shutting down the computer, the old stand-by is to take out the battery and then pull the plug. The computer will power down. Replace the battery, replace the plug and then push the start button. You may have to start it up in SAFE mode since the shut down process was not the "normal' process the computer expects to follow.
Your computer has too many sensors for your car, and the computer shut down. You need to get a computer diagnostics done on your car to see if the computer is still good. That is gonna cost you about 65 bucks to do it.
